Re: cannot reload system software without blue screen
I use a panasonic UJ-870 DVD drive and it works. You don't necessarily need a proprietary drive. Otherwise try (if you can) switching the drive off then quickly on just before the Q1 restarts at reboot.
I prefer installing/upgrading the operating system on the ix104c2 with a USB flash drive and the program "WinToFlash" and set the "Hard drive priority" to whatever flash drive you are using as the first boot device in BIOS. I recommend using a USB key board to navigate BIOS and it is required to install the Operating system.
Hi, there. This all-in-one password recovery software will surely help you out. It is capable of resetting forgotten Windows Administrator login password, and recovering lost password for multiple web browsers, mail clients, FTP clients, chat messengers etc. Next time better make a password recovery CD and put it in safe place. best regards.
If you forgot Windows password,
you can create a Windows password reset bootable CD/DVD or USB flash
drive to reset your lost or forgotten Windows password, i have created a
bootable CD with the tool Windows Password Breaker and reset my administrator password successfully.
It could be the drive failed, can you boot to BIOS at all? I'd recommend a USB Drive adapter, then pull the drive from the laptop, connect to the adapter and then plug into a working PC USB port (Be sure that PC has good/current antivirus and firewall software and it has been backed up itself). The disk should then come up and look like a regular flash drive. Recover the critical files, then back up onto something like a CD or DVD that is set aside for safe keeping. Now you can be a bit more adventurous - potentially the BIOS settings changed, or the on board battery is dead and needs changing (can be complicated). There are also bootable drive recovery utilities that you can spin onto a CD. But data recovery is always first.
Most laptops cannot boot up from a USB device/hard drive. Check the BIOS configuration to see if the USB is available in the boot order devices. In this case the USB driver is not available for use until Windows is installed. If the USB is not available in the BIOS Boot order then you need to reinstall Windows using the installation CD in the CD drive..
Yu possibly have a virus You will need to format the hard drive and reload Windows if this doesn't work you will need a new hard drive. Try to "defragment the hard drive 1st. check the disk for errors.
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
You can use an external USB drive, either CD or DVD dependent on your OS media.
I used a Phillips drive, with external power supply, to restore to factory settings using their restore CDs. I also installed Windows Vista Ultimate from DVD, without issues :)
one possible way around is to copy the entire cd (make a new folder named "CD COPY" or similar) to your hard drive (assuming you have enough space...about 800 Mb), then run the install from setup.exe from the hard drive, then delete the copy (to make room) when you are done.
