I've just acquired a used Ironman 530e elliptical and it was working just fine, but when I moved it, now the console is all messed up and not working properly. It has a mind of it's own and it will not allow me to set it up properly. It just keeps counting and stopping whenever it wants, and it's now on metrics...etc. Doesn't go to "sleep" with lack of use now and when I try to use the "mode" function, it just beeps on me...etc. Basically nothing works. I can "use" the machine, but the console isn't working. The manual is useless, because it does not give instructions of how to set it up. There should be no reason for it not to work just because it got moved. Any help you can offer would be appreciated. Thank you!!
SOURCE: Buttonhole instructions needed for Singer 7422 Advance
These are the exact instructions from the Manual.
1. Select one of buttonhole patterns.
2. Replace the presser foot with the buttonhole foot. (Install presser foot with little red mark towards the front)
3. Insert the button into the buttonhole foot. (the part located in the back crescent shaped)
4. Lower the buttonhole lever (to the left of the needle) so that it drops down vertically between the stoppers A and B.
5. Carefully mark the position of buttonhole on your garment.
6. Place the fabric under the foot. Pull out the bobbin thread underneath the fabric to a length of about 4 inches to the rear.
7. Align the buttonhole mark on the fabric with the mark on the buttonhole foot, and then lower the buttonhole foot.
8. While holding the top thread, start the machine.
*Sewing will be completed automatically.
9. When sewing is finished, use a buttonhole opener to open up the frabric in the center of the buttonhole. Be careful not to cut anyt of the seam thread.
I hope this helps.
SOURCE: I just bought a used
If you go to your local jo-ann's or hancock, they generally have a technition who comes in once a week our so to fix machines. A tune-up will generally run between $60-100, and thay should help your above mentioned problem, as well as keep everything else in tio-top shape. If there were, by slim chance, to be any additional costs associated with such a repair, the repair person will tell you ahead of time. Congrats on your new purchase!
SOURCE: I've managed to get 3D
3D Embroidery software will not work properly on Windows 7.There are no fixes.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
