I am rigging up an indoor sound system using an old Sony Xplod cassette deck (xr-ca600x). I have the unit powered up. I can listen to the radio and tapes, but what I really want is to utilize the R/L auxiliary ports in the back. I thought it would be as easy as cycling through the source menu, but when I push the source button, nothing happens. It will automatically switch over to cassette when one is inserted, but no such luck with the rear aux inputs. I've tried searching through the menu, holding source for several seconds, resetting the unit, but still no luck. Got any clues for me?
Unfortunately, the input on the rear of the stereo are Bus inputs. You must use a controller to use those inputs.
Thanks for the clue. I dug up the old cd changer that was connected to the deck once upon a time. I plugged the changer into the bus port. So now, while some random cd's spin silently in the changer, I can listen to whatever audio I want. You gave me the piece of the puzzle I was missing. Thanks again!
SOURCE: Turning off sony cdx-gt170 display
Hold the volume button down until the clock setting comes on. Then press the same button until you see "Demo:On" on the screen. Turn the volume either up or down to change the setting and then hold the volume button down until you see "AUX" or "TUNER" on the main screen again.
SOURCE: sony cdx gt200
I HAVE A SIMILAR MODEL AND I HAVE TO HIT THE SOURCE BUTTON TILL AUX APPEARS MAY BE A RADIO MALFUNCTIO
SOURCE: No sound from cd or aux on CDX-GT32W
Just connect together the solid blue wire on the main harness to the radio with the blue/striped wire. The blue wire is for the power antenna and the blue striped is for the remote amp. but if not connected together only the fm/am has outputs to the line output RCA jacks. I learned this through Sony's tech line and it works perfectly now.
SOURCE: Yes, also.... I am trying
In order to use the Aux, you must connect the source to aux port, then using the source select aux and you should hear the sound coming out.
Here is the link to the manual:
http://www.docs.sony.com/release/CDXGT20W_200.pdf
SOURCE: I have a Sony XPLOD deck in my truck, when I want
are you sure there is a cd in the deck?
Testimonial: "Thank you."
