Amana ARS2661B Side by Side Refrigerator Logo
A
Anonymous Posted on May 13, 2013
Amana freezer not freezing fridge
5 Related Answers
docjohn174
john gagnon
  • 943 Answers
  • Posted on Sep 28, 2008
SOURCE: Amana bottom drawer fridge/freezer combo
hi. thanks for the question . it sounds like you have a compressor problem . wich is under warranty from amana. great news get in touch with amana thanks the appliance doc
Techsim
James
  • 59 Answers
  • Posted on Nov 02, 2008
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Anonymous
  • Posted on Jan 15, 2009
SOURCE: my amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Anonymous
  • 52 Answers
  • Posted on Jul 15, 2009
SOURCE: Side by side Amana freezer/fridge. When you close
Possibly need the hinges adjusted.
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Oct 08, 2009
SOURCE: Amana freezer is cold, fridge is not.
You will be able to hear it when you open the freezer door and hold the door switch in.It is located behind the rear panel inside the freezer. The fan should be running when the compressor is running. If it is running make sure the damper(vent) to the fridge side is not blocked by ice and that the damper door is open.
1helpful
ART318FFDW00 AMANA fridge freezing food in fresh food compartment.Control changed,still freezing.
Either a faulty thermostat or faulty air damper that controls air flow form freezer to fridge.
Amana fridge is not cold
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
My amana refrigerator is not cooling, freezer is working
1helpful
MY FRIDGE SEEMS TO FREEZE FOODS NO MATTER WHAT SHELF OR DRAWER THE FOOD IS IN
Put the duals back to factory setting. Always the middle number and it is always highlighted. If they already are then turn the fridge only down a setting. The freezer always stays at factory I think 3 or 4 on Amanas.
Amana ABB2224DES fridge freezes everything in the main compartment (not just the freezer). Doesn't matter what the level setting is at.
Sounds like your Temperature Control Sensor has gone bad. Could also be that the door on the duct from the freezer to the fridge is stuck open due to a bad solenoid there.
Amana bottom freezer model ABB2227DES--food in fridge is freezing when it didn't before.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
My freezer side isn't freezing. fridge side seems to be working
If it worked fine to them, look at the heating and cooling C. in the back of the frig. Depending on how you transported it and how many bumbs you hit could of damanged them
Hi, my amana freezes my food in the refrigerator....
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..It may be stuck open letting in too much cold air.
2helpful
2answers
Fridge barely cool freezer not freezing
Get it checked out. It should be good for another 7 years or so. A new fridge will cost $900 to $2000 and the quality of many of the new ones is not so good.
Amana bottom drawer fridge/freezer combo is only 3 years old. It sounds like it is trying to work but both the fridge and freezer are not working. Not cooling or freezing anymore.
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
