It maybe (an) LDN(s) of the number(s) on this set, in which case forwarding will not work.
the forwarding only forwards what is directed to the set, on the extension buttons... not on other buttons.It maybe (an) LDN(s) of the number(s) on this set, in which case forwarding will not work.
Can you supply a bit more information on what you are trying to achieve?, there are two possible options on the face of it;
1~ Alternative redirect (conditional redirect)
2~ System speedcall (permanent redirect)
Let me know what controller you are using and what software rev it is running and I can assist to a greater degree.Can you supply a bit more information on what you are trying to achieve?, there are two possible options on the face of it;
You can't post conmments that contain an email address.
If all 3 phone lines are land lines, then you should contact your telephone service provider (technical customer service) because there is probably some problem with the exterior phone line connections. The wiring in the exterior connector box was probably negatively affected by your power loss.
Call forwarding typically can redirect incoming calls to any other domestic telephone number, but the owner of the forwarded line must pay any toll charges for forwarded calls. Call forwarding is often enabled by dialing *72 followed by the telephone number to which calls should be forwarded. Once someone answers, call forwarding is in effect. If no one answers or the line is busy, the dialing sequence must be repeated to effect call forwarding. Call forwarding is disabled by dialing *73. This feature requires a subscription from the telephone company. Also available in some areas is Remote Access to call forwarding, which permit the control over call forwarding from telephones other than the subscriber's telephone. VOIP and cable telephone systems also often allow call forwarding to be set up and directed via their web portals. https://en.wikipedia.org/wiki/Call_forwarding
you have to do that in the pabx setting where by you set all out going calls to be calling direct but all incoming calls to be calling to the switchboard first so change the call restriction feature
if you follow the the video I have posted you should be able to tag inbound DDIs, the phone used is the new 14 btn samsung handset, the soft buttons an a 12 btn handset are down the side but apart from that the softkeys are the same. go to http://www.abbeytelecom.com for more of these.
Hello, if you are using this phone on a Panasonic 308 or 824 system press 40 for an external incomming call or 4 followed by the extension number to pick up a certain extension that is ringing. Thank you.
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook : 1. Press PROGRAM * # followed by the system password ( default is 1234). 2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2) 3. Press AUTO ANS / MUTE to change between Connect and Not Connect. 4. Press AUTO DIAL / STORE to save your changes. 5. Press PROGRAM to exit program mode and you are done.
yea need more info on the setup to answer this one.
