I think there's a new update for the AR but I can't figure out how to install it and when I attempt to install the new update thing it won't install and it says that there's a problem(the download from the codejunkies webpage). So now I can only use it on my DS lite which is bugging me. Does anyone know how to solve this problem?
SOURCE: action replay code manager doesnt see the action replay
Many are experiencing this, what you are looking at here is a faulty action replay. go to the Datel website and submit your serial number to them, it will immediatly say whether or not your AR is from the time period when they had a problem with the internal USB reading system, if it is, then send it in and one will be shipped withing 10-12 weeks
SOURCE: my action replay wont reconize pokemon platinum
k you know how its on the list of games what you need to do:
1:put your game in
2:if you look in the bottom left corner its got a code copy it
3:look for your game in the list
4:put the indicator on it but dont select it
5:instead of selecting it hit the pencil sighn on the touch screen
6:then it should show up like how you input ar codes . since its already got the name in it press next
7:erase the code thats already set in and change it to the one you copied down then svae changes and your done
hope this helps out
Testimonial: "thank you SO much i didnt really finish what you said but now my cheats work so THANK YOU!!!!!!! "
SOURCE: Animal Crossing Wild World wont work on my action replay
have the exact same problem with mine, except its not unkown, but the 2 white bars freezing and stuff. what you need to do is restart your AR by turning off the DS and holding start select and some other button then type in the game name and id again. than it should work just fine
Also when I boot the AR it's nothing but a white screen and I can't figure out how to update it since when I go to my code manager and search for updates it says there's no new updates for the software
Checked and I have a 32 bit Windows Vista which shouldn't be a problem but I still can't update the software.
