SOURCE: Fridge leaking oil on the bottom right side
OK, usually if you see an oily substance that you are sure is not from the fridge contents it's oil from the sealed system. When a leak in the sealed system happens the refrigerant gas leaks out and the lubricating oil also leaks out. I'm afraid you may be in this situation. As the refrigerant leaks out the cooling efficientcy drops off quickly and eventually there is no cooling at all. You would have to use a refrigerant leak detector "sniffer" to locate the leak and then have a certified company repair the unit. Sadly, the cost to do a compressor replacement and leak repair is 2/3's or more the cost of a new fridge...
SOURCE: 2003 Frigidaire FRS26BH6CBO Side By Side Problem
DEFROST PROBABLY SET TO AUTOMATIC..NEEDS TO BE REPLACED THEN ALL WILL BE WELL
SOURCE: refrigerator is too cold. Freezing milk and vegs.
sounds like the solenoid door is broke or stuck ,unless you are real handy , just tape up the air inlet in the refrigerator little by little until you get it right.
SOURCE: Very Strong Odor When Refrigerator Runs
Without looking at your fridge I would say the strong rubber smell is the heater element has dust on it or the heater contactor is closed and the heaters are staying on. Either way it would be good to get it checked out. I cannot think of anything else that would make a rubber burning smell.
Hello Kelly, I appreciate your post!
From my understanding the ice within your Frigidaire refrigerator tastes funny. Odors or taste within the ice can come from strong flavors of food within the freezer or refrigerator. You should discard your bucket of ice and allow it to make a new batch, also tightly seal any containers that may cause odor issues. You may want to attempt using an air filter to help clean and contain any odors within your freezer. I hope this information is helpful to you. -Matt
Hello friend, thank you for your post!
I understand that you are having an odor issue with your Frigidaire refrigerator. Usually odors can stem from spills or food within the refrigerator. You can clean the interior with warm soapy water or warm water and baking soda.
Another home remedy is using a pan of charcoal (do not use the one that contains lighter fluid) or kitty litter inside the bottom of the refrigerator and that can help clear out an odors within your refrigerator. I hope this has been helpful. -Matt
Hey friend, thank you for your post!
I understand your Frigidaire refrigerator has bad odor inside of it. Typically bad smells inside of your refrigerator come from food with strong odors, they can circulate throughout your appliance and attach to the evaporator or walls of your refrigerator. Here are some steps you can perform to help eliminate the odor.
· Washing the walls with warm soapy water.
· Washing the walls with warm water and baking soda. Do not mix other products with bleach.
· Place a pan of charcoal inside the appliance. Do not use self-starting charcoal.
· Place a pan of kitty litter inside the refrigerator.
I hope this information provides useful. -Matt
