Hey I just replaced a bulb in my cp x345 and it worked fine for about a month and now it keeps powering off after like 5 minutes. It is mounted upside down on the roof... But when i take it down and set it on a table it works fine. There is adequate ventilation when it is upside down.
The lamp is not good
you need a Original lamp
I Supply the Projector accessories,in China.
projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price.
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
SOURCE: My Hitachi cp x250 projector powers on and
Most likely you have a defective lamp or it is near the end of its life. It's also possible that the high voltage power supply is going out. You might check the lamp hours - you can find this in the advanced menu. Also check the air filter, if you haven't cleaned it, the airflow might be restricted, shutting down the projector.
SOURCE: Machine powers down and no lamp.
one of the fans may not be working properly or the ballast is shot.
SOURCE: I have a Hitachi CP-S860
Hi dear, This is ballaster board problem.If proper voltage is not going to lamp means this will occur.so, change ballaster board.I hope this is helpful for u
