Its lock and i cant unlock it i press the menu botton and unplug it n plug it back up wild holding the menu botton but it wont work any ideas.
SOURCE: My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON
2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
SOURCE: I have a Hisense TL2020
this is an easy fix if you can solder.there are three capasitors on the power board that need to be replaced. radio shack has them for about 2.00 ea . or you can contact me.
spokane washington
SOURCE: Hisense TL2020 LCD TV
Try turning the main power switch on the back of the tv off.
Then hold the menu button and push that switch back on while still holding the menu button.
Keep holding the menu button until the setup menu pops up.
Next, be sure your input is set correctly(air or cable).
Next, do an auto channel search.
That
did it for me. After I shut it off I had to do it one more time but it
did the job. A friend of mine gave me the tv for free because nobody he
new could figure it out. I took it home, got lucky, and figured it out
in about ten minutes.
Hope this works for you.
jb
SOURCE: OSD locked Hisense PHD-4220
press menu, when osd locked appears press number 9 before osd locked disappears
