There are no instructions for descaling my Saeco Spidem Villa . I'd like to use vinegar -- since its not toxic -- but I'm unsure if it's safe for the machine. Any advice?
Hi
Don't use vinegar. Its only 5% acid at full strength and if you mix it with water a lot less. It also leaves an after taste for about 2 weeks. Use descaling powder or other products especially made for espresso machines.
Remember, it is better to descale more often than not enough.
1. To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Once it is dissolved, place the tank back on the machine, and then turn the machine on.
2. If you just open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. Longer is better. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
3. Repeat step #2 for your machine. Do this until you have consumed the entire water tank of solution (approximately four to five cycles). (I do it at night before I go to bed and let the last cycle set in the boiler till morning.)
4. Remove water tank and rinse it with fresh water.
5. Refill water tank with fresh water and place it back on the machine.
Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is no need to let it set.
