Amp prob
The speaker wire will not shut off the amp. Make sure that your power wire and ground are all connected properly. Check for any break in connections with these wires. Also check to see if your remote wire is connect properly and that there is no break in the wire. If there is a break or disconnection in any of these 3 wires, the amp will not come on. Also, check the amp fuse to see if the fuse has flown. Also check the fuse that is connected to your 12V source. If the fuse is blown, there will be not power on the amp. Check all your connections and fuse and you should find your problem
