4600 2D Imager not able to scan certain 2D Barcodes
I am Using 4600 2D Imager. And I want to scan Aztec Barcodes but my scann is not able to load symbology for Aztec Code. When I tried to load symbology for Aztec code it is giving error beep. If anyone has solution or reason for this problem Please mail me to '[email protected]'
That is a link to the PDF help file for the MS9520. It has barcodes inside that you scan with your scanner to enable/disable certain features. It looks like you should be able to enable Code 39 barcodes by scanning the barcode found on page 2-2 (actually on page 10).
unfortunatley if your device is preconfigured for 1d only you will not beable to scan or decode 2d barcodes. Which configuration of the mc55 do you currently have? if you can provide me with this information i can let you know if it is possible or not.
Datamatrix is 2D Symbology. Actually this MC55 is a model with 1D Laser Scan engine. The laser cant scan 2D barcodes, therefore he is not decoding the datamatrix barcode.
You would need an MC55 with an 2D Imager or with Camera to scan 2D Barcodes.
No, this is a Laser Scanner. The laser beam can scan the barcode only in 1 direction (1D Barcodes). For QR Barcode (2D) you would need an Imager (Digital Scanner).
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
hello
Having loaded the reader to metroset, print setting on paper and you read on paper. This player does not confugura with usb. give me answer.
Roberto
motorola mc 9090-G can't initialize Imager and we cannot scan in imaging
