Please Help..Toilet tank takes 10 mins to fill. Checked the supply line, it is clear no debris. Fill hose is in the Tube fill hole... Have only had toilet for 11 mos. Thinking to replace float mechanism.. ? Thanks in advance..
What about sand? There may be a screen in the filler that is dirty and needs to be cleaned.
There is definately a problem with that fill device in the tank. It could be one of two things. The orifice is too small because of design or machining. Or the tube that fills the BOWL is getting all the water.
there's a little screw on the water feeder pipe at the back of the toilet , check it is fully open , turn with screwdriver till it is
SOURCE: Once my tank has filled (toto toilet) the fill
The fill valve isn't adjusted correctly. Does it have a ballcock or a newer fill valve? If it's the ballcock, there's a screw in the middle of the fill valve that you can loosen to lower the ballcock. If it's newer, you'll see a float that surrounds the fill valve. It has a small metal clip toward the bottom that you need to pinch to raise or lower the float. It also has a large plastic screw with a phillips head at the top for fine tuning.
SOURCE: tank won't fill unless I push down on flush valve inside toilet
Hello there
ok first when the valve inside of the tank is wearing out or is dirty this will happen you can take a washrag and clean the underside of themechanism really good and also the part that it rests on providing that you can get to it
if there are no screws to adjust the water reg valve see if it will turn clockwise to shorten the arm making it turn off or if needed turn it counter clock wise i have had to also slightly bend the arm down in some units to make the water stop after the tank is full so you may want to try that too ok
hope that this helps
best regards michael
SOURCE: hissing sound in tank (fill valve)
Dear Sir,
It appears you need to adjust the float level so that it applys more pressure quickly to completely shut off the water going into the main filler tube. Does the hissing go away when you lift up on the float toward the ceiling? If it does, then you need to what I said above. Turn your float ball out farther, or carefully bend your rod down toward the base of the toilet so that it applies more pressure quickly. This should solve your issue.
Cro Dave
SOURCE: Need to replace all the parts inside the tank of Jacuzzi toilet
Had a simular problum.
For about $130 you can have a 1.6 LF new in box and start saving water.
Hope this tip helps.
R/
David
SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
Brad..thx for the suggestion.. I don't see a filter of any sort,. Jacuzzi support is sending me a new filler tube. BTW: Filling took 5 mins...then when I removed the water line and checked it...now it takes the 10-12 mins I posted.. ummmm ...again thx.
What type of fill hose connects to that. Almost sounds like it is collapsed OR kinked
Brad...this is what I have..Watts 3-Pack 3/8-in Compression 12-in Braided Stainless Steel Toilet .. thx for trying tohelp
Shut the water off at the valve to the wall, Unhook the flex connect to the tank, Get a bucket and direct the hose into the bucket and turn on the water. Tell me how the pressure is and how fast it fills the buck. Note you can use a one gallon jug and time it to see how long it takes to fill that.
Brad...again thxs... did so this a.m. ,, Results 1gal per 28 seconds and I did have the shutoff/pressure wide open.. Did receive a replacement part from Jacuzzi last night. Will change it out... BUT BUT the problem appears to be when the water goes into the FILL TUBE. It appears to go into a BLACK HOLE.
You have good flow and pressure. The only things it could be is the in tank valve assembly. So it is either out of adjustment, has a design flaw due to machining or other issue OR the water is all being directed to the hose that fills the bowl.
Brad..thx for all your help... Replaced the tank valve assembly/Filler/float and all is working great
