Off hook ring and Headset ring could be both enabled causing the phone to flash only and not ring
To resolve this issue
Press Menu
Press settings
1. User Settings
1. Incomming Calls
3. Disable Headset Ring
Frist u check your profile setting
secound u change ring
& now check supply of ringer & change ringer Ic
This is a phone system phone and each station you want to ring when a certain phone line rings has to be programmed into the system. This is not something you can change at the phone itself. You will either need to pay a company to make programming changes or locate a programming and installation manual for your phone system (not the phone) and try to re-program it yourself. If you have not done this before it will not be easy but it may be worth the effort so you can continue to make your own changes instead of paying someone $200 per hour to do it for you.
There is also the remote possibility your phone's ringer is broken. You can try swapping your phone with another of the same type and model to see if it will ring.
