I have a hoover 800f front load washing machine.Water leaks during drain cycle and the machine stops.
Hi
If the water leaks during drain and spin only:
A washer that leaks only during the drain/spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Please do rate this solution as "FixYa" if found useful.
Thanks
Rylee
There is a leak behind the wash machine drain and water is coming out into the next bedroom closet.
