Dell 924 All-in-One InkJet Printer Logo
A
Anonymous Posted on May 10, 2013
Dell V105 OCR software
Re-install printer driver from Dell.Ca website but didn't contain OCR software. I downloaded ABBYY Finereader, how can I attach the ABBYY software with the printer driver so that when I scan a document, it could convert into a PDF document?
buyi wen
Level 3:
Master:
Sergeant:
  • Dell Master 382 Answers
  • Posted on Sep 18, 2015
buyi wen
Dell Master
Level 3:
Master:
Sergeant:
Answers
382
Questions
0
Helped
96023
Points
1057
5 Related Answers
Anonymous
  • 105 Answers
  • Posted on Jul 01, 2008
SOURCE: 922 Printer Scanned File Email Attachment Problem
The simplest and fastest option is to compress the document with either WinZip or PKZip. That compression makes the software ignore the attachment. Both programs are pretty universal so that recipients would be able to uncompress the files at the other end. You can download the programs for free from www.tucows.com. Just search their site for those compression applications. If you are on a Mac, you can obtain Stuffit to do the same thing.
Anonymous
  • 92 Answers
  • Posted on Dec 04, 2008
SOURCE: unable to scan text doc to Word
hi i thing your software is corumpt and you nead to reinstall it. when you buy your printer you have the cd whit it. but if you don't find it you cant download the torrent of ocr
bye and good look
Anonymous
  • 564 Answers
  • Posted on Mar 21, 2009
SOURCE: I can't scan a document into a Word file...
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
PREM
  • 6688 Answers
  • Posted on Jul 25, 2010
SOURCE: I have hp color printer with scanner. I need to
If you do not have the install CD that came with third-party software (or you have a OS that is not compatible with that software), you will need to get a OCR program. SimpleOCR (http://www.simpleocr.com/Download.asp ) is free but doesn't handle pages with columns well. (It merges across the column breaks instead separating the paragraphs.) It also doesn't handle handwritten text. This software outputs to a file for a Word Processor (such as Microsoft Office's Word). Most word processors either come with a PDF converter or have one available as an add-on. The commercial OCR software packages will include the save as a PDF function and do not have the limitations of SimpleOCR; although they also default initially to a format for Word Processing (to correct any mistakes). (I have used OmniPage at times personally.)
With most all-in-ones, if you have the full software installed, there will be an option for saving as a PDF. (This is true even on the versions that weren't bundled with OCR software.) If you have a generic OS driver or the basic driver, this will usually not be available Take a look at the screens that come up if you start the scan from the computer. (There will be a place to adjust settings, including the resolution and the output type.) This won't be editable unless you go through the OCR software.
I hope this helps.
Anonymous
  • 1325 Answers
  • Posted on Feb 09, 2011
SOURCE: I lost my dell 926 all in one printer install
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&os=WLH&osl=en&SystemID=PRN_ALL_A926&catid=-1&impid=-1
Brother MFC7820-N won't connect to ABBYY Finereader Pro for Mac
This is the software brother recommended for your printer...Download the software from the link given below: Download Brother
MY SCANER IS NOT WORKING
Try running Delete Print Jobs to remove any stuck print jobs in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
Download the proper drivers. If using Windows 7 32-bit use the Vista 32-bit and if using Windows 7 64-bit use the Vista 64-bit drivers. Install the drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Virus programs and firewalls will block communications.
Links to the patch(drivers can be found at...
Dell 926 Photo All-In-One Printer owners thread (W7)
As for scanning, if you have the disk that came with the printer, then insert the Printer disk and stop it from running. Go to My Computer and double click on it. Look for the drive with the Dell disk in it. Right click on it, left click explore. Look for the OCR Folder. In the OCR Folder, there is an Abbyy Folder. right click on setup.exe, that's in the Abbyy Folder and left click run as administrator. This will install the OCR program.
Or
Try Simple OCR
Rick
2helpful
I have a Dell V105 scanner printer. I am able to scan a document as a picture, but no text edit is possible. I do also have ABBYY fine reader 6.0 Sprint. What am I doing wrong? I do have the Dell...
Once you have scanned a text document you need to use an OCR (optical character recognition) program to convert the scanned image to text. This text document is then copied and pasted into a Word document to edit, amend and correct spelling mistakes created by the OCR program.
There are freeware OCR programs on the Internet as well as commercial programs.
Check out these freeware OCR programs from these WEB sites.
http://www.makeuseof.com/tag/top-5-free-ocr-software-tools-to-convert-your-images-into-text-nb/
http://www.freewarefiles.com/category_3_41.html
2helpful
2answers
I cannot get ocr with my F4180 Can you help please
You can download the trial version of the OCR from the following link :
http://finereader.abbyy.com/trial. This is the best OCR software available
3helpful
2answers
Wanting to scan to microsoft word
Please note that the OCR software is a third party software which is available in the Lexmark Installation CD itself. However, please click on the link given below to download the trail version of the OCR software:
http://www.download3000.com/download-abbyy-finereader-8-professional-edition-count-reg-46361.html
NEED OCR SOFTWARE FOR C3180 ALL IN ONE
www.softpedia.com/get/Office-tools/Other-Office-Tools/ABBYY-FineReader-OCR-Professional.shtml - 88k
U can Download it from the above Link
Good Luck
1helpful
3answers
OCR application error with the Dell ALL in ONE
OCR is a software provided by Dell to convert a scanned document to editable text(word) document. If you scan without OCR software, printer will scan it as a Picture and you can not edit it.
Now here is your answer.
When you install Printer CD, it also install OCR software (Abbyy Fine reader) along with it.
You might have uninstalled the printer drivers and reinstalled them by downloading it from Dell support site.
I must tell you that Downloaded drivers from Dell site DOES NOT contain OCR software.
Solution:
1. You can download free trial version(15 days) from Abbyy.com
Click here to download
2. If any of your friend or relative have printer listed below then you can use the same CD to install the OCR software.
List: Dell 924, Dell 926, Dell 928, Dell 944, Dell 946, Dell 948, Dell 964, Dell 966, Dell 968.
location on Disc:
D:\OCR\setup.exe
3. You can scan using MS Paint.
Click on Start > All Programms > Acccessories > Paint
Click on "File" on Top left corner.
Click on "From scanners and cameras"
Click on "Scan"
It should be able to scan.
4. If you want to use Dell All In One Center.
You can disable OCR option for scanning and it will scan as an image.
Open Dell All in one center.
Click on Advanced scan options Under scan,
Uncheck "Use OCR software".
Click OK and try to scan again using Dell All In One center or using the printer operator panel.
Please revert for any further assistance.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
