I had a number of personal pictures and videos on my laptop which i later copied them all on my pendrive and later deleted all my files from my laptop. I then gave my laptop to a service centre for servicing. After i got it done i opened my pendrive to check my images and videos which i was unable to view most of my images and videos from the pendrive. The error i get everytime i view my images is "Filename, directory name or volume label syntax is incorrect" for some pics and for some i get the error saying " The image refers to a location that is unavailable. It could be on a hard drive on this computer, or on a network. Check to make sure that the disk is properly inserted, or that you are connected to the Internet or your network, and then try again. If it still cannot be located, the information might have been moved to a different location." The file names have weird characters and im unable to understand the issue. I tried recovering my images from Stellar phoenix windows data recovery and managed to recover few pics but unable to recover the others neither could i recover the images from my pendrive. I wish to get my images and videos back. Kindly please help.
SOURCE: Is it possible to restore from shadow copies of a crashed harddisk?
My harddisk crashed with lot of important files on it. I sent it to a trusted recovery service.
how can possible restore delete any file & folder on my pc harddisk
SOURCE: External Hard Drive I/O Error
Somehow i tried to format and it was formatted. took pretty long time as 1 terabyte. i thought all is ok as the drive was accessible. Just to double check, i scanned the drive thorugh the seagate manager and it got stuck on 10% for few seconds and then said that the hard disk is faulty and should be immediately returned if under warranty. and to confirm it also gave me read errors http://www.dtidata.com/resourcecenter/2007/05/15/how-to-tell-hard-drive-physical-damage/
so i'm giving it to seagate service centre as it probably has physical faults, bad sectors. and someone told me that 1TB hard drives are not stable.
SOURCE: Hard Drive recovery
Go to the link below for a program that may get your data recovered - OR do a search on Google for "hard disk recovery" - depends on where you are - US, Canada - it will cost about $200 dollars to get your data back
http://www.stellarinfo.com/disk-recovery.htm
SOURCE: Recently my external hard disk freezed. i
i would check the image you have saved before formatting your external drive just to make sure you will have it after a format you will lose all data if you can see your external hard drive right click on your external drive select properties tools check now you should check now with two boxes you could tick both boxes automatically fix files and attempt repair bad sectors on your drive have no input while chkdsk utility is in progress any may damage this external drive also click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x if you can see your usb but its not working check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems if this fails to fix the problem
right click to reinstall drivers
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope some of this helps you
SOURCE: my external hard disk stopped functioning , i need my data please!
It sound like the platters are skipping across the hard drive AU $8.40 Buy it Now + postage AU $0.96 or you might be able to find one closer for local pick up Yes you would have to remove the hard drive and use a usb sata ide kit you will have to connect it to your computer using a usb port http://www.bing.com/images/search?q=SATA+Power+Splitter&qpvt=SATA+Power+Splitter&FORM=IGRE once connected to another computer to a usb port and power supply you should get a message found new hardware and it should install the drivers it should show on your computer or you might have to install it manually click start click on computer to open you should see this drive if you dont click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver once you see this drive just click on it to open and copy all or any data you want and save it to another usb drive hope this helps or get one of these
http://www.ebay.com.au/itm/120738767650?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable
NEW!2.5" SATA TO USB 2.0 external HDD enclosure case AU
I have done recovery on my own hard drive and it does work.
http://download.cnet.com/data-recovery-assist/3000-2248_4-75104099.html
Data Recovery Assist allows you to recover lost, deleted, and formatted data on local and network drives, as well as removable drives. Data Recovery Assist supports Hard Disk, USB Drive, SD Card, MMC Card, Sony Memory Stick. Data Recovery Assist can recover deleted files emptied from Recycle Bin, lost data due to partition damaged, software crash, virus infection, unexpected shutdown or other unknown reasons. Data Recovery Assist provides a comprehensive data recovery solution for computer users to recover lost data. Data Recovery Assist Supports FAT16, FAT32, NTFS and other file system. Data Recovery Assist Supported all major file types, include text, exl, pdf, bmp, exe, html, jpg, avi, mp3, email, word and so on. You can preview deleted file before recover it. Operating System Support: Windows7, Windows Vista, Windows XP, Windows 2003 and Windows 2000 Release Note: 2009-10-28 Add deleted files written-over caution,It's very important! 20010-01-01 Update skin and support vista and win7
