Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
Posted on Mar 17, 2009
Seagate Free Agent drive wont power up
Seagate Free Agent drive was working fine, when I plugged it in today it would not power up. Any ideas? I see lots of posts for the same problem but no posts for solutions
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 23, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
8069
Points
8
It you are using the notebook, this may be the solution for you
http://hk.myblog.yahoo.com/xiao-laba/article?mid=1861
My Seagate Free Agent GO is not working. My laptop does not detect my external hard drive and external hard drive does not power up. Before it used to work good.
Either the power outlet it is plugged into does not have power or the AC power adapter for the drive has failed. Try another outlet. If that doesn't work see if Radio Shack has a replacement AC adapter or contact Seagate to replace it.
I hope this helps.
2answers
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
1helpful
Free Agent Desktop Wont turn on
I had the same problem and assumed the drive must have been at fault. However, I noticed the power supply (wall wart) wasn't warm as it had been when everything functioned. I contacted Seagate support and they sent me a replacement power supply. It has since failed, but in the interim I found a heavy duty laptop-type powersupply with the same specs. It has worked fine since. Since your unit doesn't power up, I'd check that first. It's the easiest, least expensive thing to do.
I plug my seagate into the computer. it turns on but then nothing
Plug one usb into your computer and the other end into the drive.
If the light comes on, all is good. The computer should install the device for you automatically. To access the drive, go to My Computer and double click on the Removable Drive. Now you can transfer files.
Hope this helps
Chris (ziraffa)
2answers
Installation issue - Not recognizing
hmm, no problem plugging in either side, just be sure to do the power cable first. What's doing the beep, beep?
Found a guy who had similar prob, here was his solution:
Go to Control Panel. Click on Device Manager.
Check to see if FreeAgent is shown as a disk drive.
If not, check the device list for any Free Agent device, double click and check driver. No driver installed? Update does not work? On the driver tab….click uninstall device.
Shut down computer. Unplug Free agent USB and power at the drive.
Reboot computer. As it is rebooting, plug in the power cord. Wait a minute or two….then plug in USB cord.
Windows will “found new device” ….. Just let the computer complete the reboot.
Then go to the device manager. Chances are you will find Free Agent in the drives….and in the USB list of devices. Open windows explorer….and you should see you Free Agent as a drive.
Windows will ask you to install manufacturer disk. You have no disk…non needed. Windows has installed the device. Just click on close. I you keep getting windows wants to install device…..ignore it. You can click on “don’t ask again”. (That is if your Free Agent drive is showing in the device manager as a disk…and in windows explorer….along with your other drive or drives.)
If at some later time….your Free Agent drive does not appear….repeat the steps as listed above.
(You may think it is not working….or that it has gone bad. Try this before you try to return.)
Seagate Tools…the new version….does not recognize to diagnose the Free Agent….
I have not tried Seagate Tools after getting the computer to recognize the drive.
I am surprised Seagate does not provide a Tool to recognize their own drives…and install and/or test Free Agent.
This does work for me with Vista. Thought I had lost the drive…. Seagate should provide a patch or a drive that Windows will recognize when you get the “found new hardware” and Windows asks you to insert manufacturer’s installation disk. I do not understand why that is not already there….a driver file for Free Agent...that Windows would install.
I did not buy Pro….because I did not need the backup software. I wonder if those who bought Pro are having these problems.
150 GB Seagate Free Agent external problem.
Yes, this could have blown an internal thermal fuse.
2helpful
4answers
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
