Question about RIM BlackBerry Pearl 8100
Camera Light Won't Turn Off!
The camera light on my blackberry pearl won't turn off and stays on constantly unless I take the battery out. Even when I check that the flash is on Off, it doesn't work. Even when I turn the phone completely off, the flash stays on. Also, once I take the battery out, the second I put it back in, it turns on again. When I'm on the video setting and I press the space bar to turn the flash on, it becomes brighter once set to on but goes back to this already super bright when set to off. I've read a couple other forums for this same problem but the only advice found was to go to the store and get technical help for it. Please and thanks for any insight or help!
  • 1 more comment
  • 918496 Apr 14, 2009
    Everytime i put my battery back in my camera light turns on, i have tried everything, blackberry 8100 does not haev a video camera.. i am thuinking about taking it apart myself and cleaning everything out, wiping it off and using a air soft spray can on it. is that a good idea? is it hard to put back together?
  • snibley Apr 23, 2009
    Same exact problem here. This morning the light turned on and it won't turn off unless I pull the battery out. I tried updating the firmware, but it didn't help. The weirdest thing is that when I turn on the camera app, the flash turns off, but it turns on again as soon as I close the camera. Really frustrating. All the message boards I've seen don't have a solution.
  • Anonymous Apr 24, 2009
    dropped phone in water now it will not turn on
    New Friend:
I have a 9700 bold and the same thing happened. Flash stays on even when battery is removed and left out for a whole day! as soon as you put th ebattery back. Flash is back on!
Out of fusrtation i gave it a slap and the thing turned off and is now working as normal again!
Posted on Jun 04, 2010
  • 170 Answers
If your BB has the video camera function go into it, and then into the options and check and see if the video light is set to on or off, My turns off with the video camer but your may be set to on???
Hope this helps...
Posted on Mar 17, 2009
  • 3 Answers
Had the same problem.
Bashed the BBry onto a tabletop in frustration.
Light went off.
Posted on Apr 04, 2013
SOURCE:
Blackberry pearl 8120 just died and despite recharge won't turn on
turn it on press anything that would make a sound is the display go fix itit wont even turn on check the charger and battery if nothing works theres not much that you can do other than sell it for pieces ;)
Oct 04, 2011 | RIM Cell Phones
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
My pearl flip 8220 has its camera light stuck on how do i turn off
go to camera, the go to settings, then choose the lights, click the off options
Aug 08, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Radio keeps shutting off
When there is no signal around ur blackberry will shut off the radio instead of constantly searching for one which really kills battery power just make sure you arent in a real signal dead area and you should be fine to turn it back on just go to manage connections and click it back on,if this is not the problem then there might be some problem with ur phone.
Jul 12, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Blackberry pearl camera light wont turn off
I solved it!! All I did was take the battery out for about an hour, put it back in and charged it for an hour, then turned the phone on and it has worked ever since.
Jun 25, 2009 | RIM BlackBerry Pearl 8100
Restart your cell phone and try it again.
Do you know what the version number is for the software on your phone?
Feb 25, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
RIM BlackBerry  Pearl  8100 Logo
4,600 people viewed this question
Top RIM Computers & Internet Experts
Otman Lahlou
Otman Lahlou
Ekse
Vincent G
Vincent G
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
