Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
What will make a oven come on with the oven knob turned to the off position?
My oven keeps coming on by itself even though the oven knob is on the off position. I was wondering if somebody could tell me what it could be and how to fix the problem. It comes on and stay on for a few seconds but then it will kick off by itself. This is starting to worry us that it keeps doing it.
    New Friend:
  • 21 Answers
Maybe your knob is turning but the rod the knob is connected to is not turning. Best to remove knob and turn the rod to off position with Pliers to be sure it is actually being turned to the off position.
Posted on Jan 15, 2018
5 Suggested Answers
6ya staff
SOURCE:
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Oven turn's on, keep's heatings at a higher temp.
This is failed communication between the EOC and the temp sensors located in the oven. i recommend testing the EOC(break point test on the pins) for its operational value and the temp sensors as well. replace any component that doesn't register.
I would also inspect the oven temp sensors for welded harness and fouled housings.
In most cases, this will be a EOC issue.
Posted on May 25, 2009
milten1
milten1
  • 1304 Answers
SOURCE: frigidaire self cleaning oven model # 316255347.
absolutely nothing, they are cycling properly to keep the glass top hot
you are not cooking wioth the heat of the element,
but with the heat the glass absorbs from the element
if they are all doing it,,,, it is normal trust me
i have handled this call about 500 times since glass tops first hit the market
Posted on Oct 22, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: my self cleaning oven door will not open, and keeps beeping and
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%^@#
Posted on Oct 01, 2010
chrispolkele
Electrolux
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Probe light on convection oven stays on. Clock won't display. Oven still works though.
    Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
    Posted on Aug 14, 2012
    Oven not working
    Gas stove check gas oven safety value
    Mar 17, 2014 | Ariston Technologies Ovens
    Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
    The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
    May 10, 2011 | Stoves 720EF Electric Double Oven
    Bottom oven element stays hot will not cut off
    In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
    Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
    Mar 03, 2011 | Ovens
    The oven will not turn off even though both dials are in the 'off' position. The light remains on and the fan continues to run. The oven continues to produce heat.
    Hi make sure the knob on the switch is not loose and slipping on the switch. hope I can help Regards Billy
    Feb 24, 2011 | Ovens
    I have a Fridgidaire Galaxy Oven,can you tell me how do I set the self cleaning oven?
    Greetings,
    I can't locate your model number, but, if you have the one with an electronic control..just put it to clean and maybe set the clean time and it should start the cycle and lock the door by itself and start cleaning.
    if it has knobs for selector, and a knob for oven thremostat and a clock with two or three knobs.
    put the selector on clean, put the thermostat on clean and then go to clock and set the stop time three hours past the time thats showing on your clock(providing its keeping time) and lock your oven door and it should start.....Bruce Denton
    Dec 13, 2010 | Frigidaire FFEW2725LB Oven
    Bottom oven is not working even though the top one is 720EF model
    When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
    As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
    I hope this helps.
    Sep 17, 2010 | Stoves 720EF Electric Double Oven
    I have a arrow oven and when i plug it in and turn the socket on the oven turns on even tho the oven is in the zero position
    Most likely the fastening screws on your knob might have come loose and shifted position. Turn the knob anticlockwise i.e.towards left of "0" position and see whether it will move. If it does, then your knob is loose. If the knob does not use a fastening screw, then the spring clip/the center hole of the knob is enlarged resulting in the knob shifting position. Replace the knob.
    Dec 22, 2009 | Ovens
    Miele steam oven keeps wanting to be descaled after descaling!
    yiou have to enter in service mode. ' 1- turn oven to off position 2- open door 3- turn knob counter clock wise to defrost position 4- push 3 times tempeture button until #02 appears on screen 5- with the + button go to 67 6- close door and wait 5 minutes until it resets by itself. enjoy your oven once again.
    Dec 18, 2009 | Miele DG155-1 Steam Oven Single
    Hotpoint Glasstop Stove - Burner turns on by itself
    I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
    Oct 08, 2009 | GE Profile JKP18 Electric Single Oven
    Oven will not lite
    Unplug the unit, change the igniter maybe it does not draw enough ampage.
    or check the gas control knob if somebody mistakenly turned it to off position. the ON position should be inline with the gas pipe.
    Dec 18, 2008 | Frigidaire FGB24S5A Gas Single Oven
    Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
    146 people viewed this question
    Top Frigidaire Ovens Experts
    Marvin
    Marvin
    Bruce Denton
    Ekse
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
