When the game is loading, I get a message to attach nunchuks. I want to play using standard controllers. Where is setting 2 to play using Wii remote only?
That depends on the game. some games require both wii mote and wiimote+nunchuk. IF the game has an option to disable this however, it would be in the main menu's options screen.
Hi there, the nunchuck is actually a separate controller that is needed. It is plugged into the end of the standard Wii remote with a cable. The nunchuck does not require batteries so I am guessing you are getting confused between the nunchuck and the Wiimote. Please look at this photo to see what I mean about a nunchuck.
Well, I don't use the Wii wheel. I played with the gba and Game Cube controller. So I recommend to try using the nunchuk in your races. Play Wii play to test your wii remote's pointing and twisting ability's
If you hit "+" during the game, it should bring up a menu. You will likely be able to view the controls there.
Otherwise, I would assume that you walk using the joystick on the nunchuk and turn by aiming the wii remote.
Same happened to me. Here's the fix... While in the game go to options. Now click on the top of the menu wher it says CONTROLS. You will then see the option to select Top Shot style. At first it seems like the word CONTROLS is just a header but it is actually a button you must select. Hope that helps.
There are two optaions for you to find one, one of the simpler ones would be to find a video game store and ask if they have the booklet in stock and they should be able to give you one, or you can try e-bay, im sure there is something on there. I hope I have helped you in anyway.
double check that game is compatible with your system, if it came with it the you may have a faulty machine. Also, double check your connections for your controllers and the nunchuk if connected. Jay
