Question about Sony Ericsson XPERIA X1 Smartphone
Touch screen is not responding on my x1
Hello guys,
I got my new X1 few days ago, and today when i woke up i found out that the screen is not responding to touch...the stylus does nothing. I attempted a hard reset, but I can't align the screen because the stylus still does not work.
I managed to go to today screen and the mouse is working perfectly but touching the screen is not working at all, even through alignment.
No apparent cause to that.
Any idea how to fix this issue?
Thank you,
  • 1 more comment
  • Anonymous Apr 15, 2009
    same
  • Tayas May 08, 2009
    I have the same problem and unfortunately the fault is not covered under warranty as they claim to say it is due to water damage.
    Can somebody supply me with the details of a reliable repair centre to get this fixed! Thank you
  • zjalloul May 30, 2009
    Thank you zohail,
    I already did that and got a new silver x1 and it si working perfectly.
    thanks
    President:
  • 1,223 Answers
Ur TOUCH PANEL IS FAULTY kindly go for warranty claim or tell me i can give u link for the out of warranty replacements
Posted on Apr 10, 2009
  • 1 more comment
  • Shoaib Rais
    Shoaib Rais May 28, 2009
    100% Digitizer Fault pls get it replaced
    I was here to help
    I was trying to help and it is Free as u know i am not getting any
    financial gain from helping u, the only thing i need is good rating, so
    kindly update ur rating for the solution and more questions are welcome
    Regards
    Zohail
  • Shoaib Rais
    Shoaib Rais May 31, 2009
    pls update ur rating to FIXYA
    Regards
  • th3arian Dec 27, 2011
    hi..i bought x1 with a faulty rom init.i tried to hard spl bt it didnt workd as i culdnt selct the usb conectn.i trid to cpy the rom manualy on mem card then restrtng n intlng bt it said no image file.nw im stuck wth a faulty fone.kindly help me out.im nt in wrnty.thnks
    New Friend:
  • 13 Answers
Touchscreen not responding is due to faulty flat flexible cable wire which is the most common problem on SE Xperia X1, so many users
experience this problem until now.
Some other problems related to this are black screen when the slide is out or open, it hangs up on landscape mode.
I read a blog which exactly tells you how to fix it.
here at Free Cell Phone Repair Tutorial
Posted on Jul 09, 2010
    New Friend:
I have the same problem,. X1 touch screen not working with stylus. Is it covered under warranty??alam alamctc@gmail.com
Posted on Jul 08, 2010
6ya staff
SOURCE:
Kenwood KM-X1
I suggest build new non-powered woofers with cabinets.
If you really get serious with your sound you'll need a workshop
for customizing it all. A converted garage is nice.
See mine in photo for an example:
Oct 13, 2017 | Audio Players & Recorders
Tip
China touch screen repair solution
Touch Screen IC 4182A and MT6301 same. See X- X+ Y+ Y- reference my picture jumper.
Touch Screen use of 4-wire resistance screen, four lines are: X1, X2, Y1, Y2
X1, X2 in the horizontal direction for a change in the resistance, Y1, Y2 for the longitudinal resistivity.
How do you know which line is a two x1 x2 y1 y2? Touch panel along the four lines above are facing their own look at the screen from top to bottom in the line is about on both sides of the x1 x2 is y1 y2. Established phone touch screens measuring four points of the voltage. Two 2.7V and two 0v . two voltage are measured after boot. 2.7 v is y. X is not the voltage.
After corresponding with xy can generally be connected. If the touch panel screen and click position opposite or reverse. Swap contrast x-y reversed.
on Jan 06, 2010 | Cell Phones
X1 reset of tyre pressure warning on dashboard
I had a small nail in the near new tyre that BMW service said needs replacing. I took it to my local tyre guy and he fixed it although he said he shouldn't. Happy days!
For X1 you need to turn engine on and use the scroller on the indicator stalk to get the reset indicator, then hold the BC button on the end of the stalk for 5 secs. I had to do it twice but prob solved.
Believe it or not, it's in the owners' manual...
Sep 27, 2012 | 2011 BMW X1
Touch Screen is dead on my xperia!! Help plz??
digitizer is busted. You can try to pull it apart using a guitar pick and check the ribbon cable, but it's probably a goner. Sorry for your loss, touchscreens hate falls.
Dec 21, 2017 | Sony Ericsson XPERIA X1 Smartphone
I dropped my phone today i switched on and everything was working besides the touch screen ..please help
Please switch off your Sony Ericsson XPERIA X1 phone and putout the battery from phone after few minuts again insert the battery into the phone and switch on it. I believe your problem will be shout out.
Vinay
Dec 03, 2010 | Sony Ericsson XPERIA X1 Smartphone
Hello, please HELP me!!! SCREEN NOT WORKING
Contact Sony Ericson service for repair and collect the costs from "some1".
Feb 07, 2010 | Sony Ericsson XPERIA X1 Smartphone
My turtle beach x1 wont turn on?
The green light (or red if it's muted) should glow on when you plug in the USB. If it doesn't, it means there's a problem with the power feed to your X1 and you should contact Turtle Beach tech support to get it fixed.
Aug 07, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
X1, aluminium: no water filtering through
It is possible that the coffee screen area is blocked, since the steam and hot water work? Try removing the screen and cleaning.
Aug 03, 2009 | FrancisFrancis! X1 Espresso Machine
Sony Ericsson XPERIA X1 Smartphone Logo
1,917 people viewed this question
Top Sony Ericsson Computers & Internet Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
