Dryer has no heat. Would like to check fuse but don't know where to look.Do not have my manual.
SOURCE: dryer will not run or heat
Could be the thermostat or element....Element should read around 32 ohms on multimeter..stat closed circuit.....Try to look for any overheat cut off at the back anywhere...
SOURCE: mod. MDE9700AZW good mor. dryer runs ,but no
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
heatman101
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
hermal Fuse
Another possible cause for a dryer not
heating up could be attributed to a faulty thermal fuse. Once a dryer's
thermal fuse has blown, it is no longer of any use. If your dryer's fuse
is blown, you will have to replace it. Open up your dryer's cabinet and
locate its thermal fuse so that you can test it.
Thermostat
If any of your dryer's thermostats have
become defective, they could be the reason that your dryer is not
heating. Open up your dryer's cabinet and test each of your dryer's
thermostats. If any are faulty, replace them.
Timer motor
A defective timer motor could also
cause your dryer to not heat up. Test your dryer's timer motor. If it is
no longer functioning as it should, replace either the entire motor
assembly, or just its motor.
