I have an Aiwa Z1600 home audio system. I'd like to clear all the pre-set stations. How do I do that?
There's no clear all settings there. You need to manually delete each saved station. Try to unplug the power of the unit for few hours and check if that clears all.
Press the tuner band and the power button at the same time. Go to Mono-press the tuner band and power button at the same time several times. Go to AM mode-press tuner band and power band at the same time, repeat several times. This should do it; if not-contact [email protected].
If switching off mains power to the unit does not reset them, you can simply overwrite the existing pre-set channels with new ones... You don't really need to delete them all to set new ones.
To set new ones, follow this procedure:
Begin by selecting either the AM or FM band. Tune in the desired station by pressing the DOWN or UP buttons. Press the SET button. Within four seconds, while the preset number is flashing, press the SET button again to store into the memory.
Repeat these steps to preset remaining stations.
Please intimate exact model written on front of Aiwa unit.
Z1600 is apparently incomplete model number.
Thanks.
Your response has been the closest to what we where looking for
