We have an "Incompatible Cartridge" error even tho it's an HP 95 cartridge. We had the HP 95 colour cartridge refilled, but the printer says it's incompatible. Any suggestions on getting past this error?
You can contact the HP Printer Support Phone Number 1-844-355-5111 to solve cartridge error, as the customer service executives can take your call and then transfer it to the technical team, who can help in providing with the best possible solution for your HP printer.
HP Printer Support Phone Number 1 844 355 5111
Try uninstalling printer, reboot computer then reinstall printer drivers. do not accept HP updates as they block non HP consumables. Update manually if needs must.
SOURCE: Printer does'nt work with non H P cartridges
It is pretty clear that you have a defective color cartridge. Return it to your vendor for a replacement. You may have some success cleaning the contacts as shown here, but most likely you need a warranty replacement color cartridge.
Regards,
Bob Headrick, MS MVP Printing/Imaging
SOURCE: how do i make printer accept refilled cartridge t
Maybe you did not refill and insert it very well.
follow this steps in refilling your ink
1. remove the ink cartridge from the printer
2. make a hole at the top end of the cartridge, the hole can be made under the label on the cartridge by using a sharp/hot pin.
3. if you are using a syringe and needle in refilling, make sure you did not insert it into the hole too much so that the cartridge does not get damaged in the process.
4. make sure the ink is not over-filled to avoid spillage which can cause a hell of damage on you printer as it does to my previous one.
5. Gently use the label or a masking tape to cover the hole and insert it into your printer.
Note: The printer gives a message that the cartridge is empty or non compatible, ignore the message and continue with your printing.
It is also advisable that you refill your cartridge not more than 2 times.
If this solution does not help you, contact me on [email protected] for more assistance.
SOURCE: HP photosmart C4480 printer cartridge incompatible error BEWARE SPAM NUMBER BELOW 1-800-532-4187
Well....I solved the problem......bought a new Canon printer!!
I tried everything...unplugging, cleaning everything that was mentioned above. I was onto HP online support several time, but they were absolutely no help at all...they basically told me that the cartridge must be damaged or ink dried up and to buy a new cartridge to see if the error persisted.....I don't think so!!!
I will never by HP again after having issues with the last two I have had. I love my new Canon printer it is EVERYTHING that HP wasnt.
SOURCE: my HP C4480 will not recognize the refilled
These cartridges have expiration dates, they can be refilled until they hit that expiration date, Either go to a real refiller that will put a new chip on the cartridge or take the printer apart and remove the battery inside it, Walgreens doesn't know what they're doing when it comes to refilled cartridges
