I did firmware update on my router Dlink DSL 2730U. After this even the power light is not glowing.
When I connect LAN wire from router to laptop, then I can find LAN light of my laptop blinking.
But it could not establish a successful connection through LAN.In "Local Area Connection Status" I get below status
Status: Limited or no connectivity
IP address 169.254.157.182
I have done all kind of reset but in vain.
Is there any way out?
You will need to connect Via the ethernet port on your Dlink and Computer direct first then you can configure your router from there and reestablish the web link afterwards.
Attempt to do the firmware update, again--connecting always to ethernet for firmware updates. Unfortunately, your modem may be "bricked" (unusable)--in other words, it may be time to recycle it and buy a new one.
The firmware may proved damaged--given that the incorrect firmware successfully installed (hopefully, that was prevented by the device itself--it may have output an error message or code)--or, it was installed incompletely, or the update proved corrupted.
Two possible causes for this:
1. Power fluctuations has caused the AC to DC power supply to over supply the router with current. This will damage the router's electronics. Solution to this is to buy a new router.
2. Updated firmware: if you updated the firmware and the new firmware got corrupted during the download, you could experience that problem. I will suggest to revert back to a previous version if this occured.
Make sure you download the correct firmware for you Hardware.
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem hardware (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
There are many reasons why this might be happening.. You could try the following steps..
1) Disconnect the power from router for a minute and reconnect and check.
2) Try changing the wireless channel and Network name and try re-connecting and in change LAN slots at the back of the router.
3) Check if there is an firmware update for your product and update if any update is available.
4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing. - Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer. - If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
