Have Baby Lock 1556. Removed shuttle hook to clean shuttle race. Can't get it reassembled. Manual isn't much help.
The hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Kent
the hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Kent
Kent, Thank you SO much! I have had my BabyLock1750 for 15 years but don't use it consistently. I tried to clean and put back together and couldn't get it to work. Your solution was Perfect! :))
hi Kent n Munkinp i have the same problem with the machine .i tried to solve as per u wrote but hook cover is not properly getting adjusted.when i fix both the things then machine become very hard to drive.even i feel needle may break down. what to do .
I tried the instructions and having the same cannot adjust the bobbin jams and the needle gets jam
Here your shuttle assembly when you clean and pull out
foolow the shuttle race assembly check the position of shuttle foolow this set up as you can see there are two lever lock of shuttle race
after you installed push the two shuttle race lever lock, to lock the shuttle/sometime there is bolt to lock.the insert bobbin,but be sure bobbins winder exactly follows onCan't reassemble shuttle hook and shuttle race - fd4fd62.jpg. thead in bobbins is clockwise in retationfollow the direction of thread then hold bobbins latch to inset this is the position of bobbin going toshuttle race assembly.ignore arrow.have a nice day regards
here your shuttle assembly when you clean and pull out
this your shutle race cover attached this to your shtuttle race to cover as in the position shown
after you installed push the two shuttle race lever lock, to lock the shuttle/sometime there is bolt to lock.the insert bobbin,but be sure bobbins winder exactly follows on the figues. thead in bobbins is clockwise in retationfollow the direction of thread then hold bobbins latch to inset this is the position of bobbin going toshuttle race assembly.ignore arrow.have a nice day regards
hi! try to insert the shuttle accross the shuttle race where the hook coincide inside shuttle race then put back shuttle race cover with the level lock.
Problem solved - delete problem
Problem re shuttle hook is resolved. Please delete problem.
Thank you
was working fine until i decided to clean it. I've put this thing together many times before. Blonde moment? Now, the bobbin won't 'catch' when I have it assembled. Seems like the 1/2 moon is backwards from what I remember. I just want to keep sewing and i'm stuck. help!
hi! is there any similarity of your shuttle hook like in this fig. i've been searching your manual but unfortunately i got different brand
if this ok to you.you can visit www.sewingmachinemanual.net if you want try to locate your manual.
