Samsung RS2556 Side by Side Refrigerator Logo
Posted on Mar 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SAMSUNG RS2545SH FREEZER SIDE BLINKS AND THAWS WHEN AT WORK
LAST WEEK-CAME HOME FROM WORK AND NOTICED WATER ON FLOOR AND FREEZER LIGHT BLINKING WITH THE FREEZER PART THAWED.  FOLLOWED INSTRUCTIONS TO RESET, VACCUMED BEHIND, UNDER, (NOT DIRTY) AND MADE SURE ROOM BEHIND FOR AIR FLOW.  WORKED GOOD UNTIL TODAY WITH THE SAME PROBLEM.  CALLED SAMSUNG FOR HELP AND THEY ONLY GAVE ME A NUMBER FOR SERVICE.  I CAME TO THIS SITE AND NOTICED PEOPLE HAVE SIMILAR PROBLEMS WITH SAMSUNG SIDE BY SIDES.  IS THIS THE ONLY THING TO DO BEFORE CALLING SERVICE?
  • AlanHebert Mar 17, 2009
    I have the same problem with RS2555SL.  Please let me know if you have found a solution.  I would love to troubleshoot more before calling for service if anyone has advice.
Anonymous
Level 3:
  • Master 700 Answers
  • Posted on Mar 21, 2009
Anonymous
Master
Level 3:
Answers
700
Questions
Helped
306849
Points
1781
Check to kake sure that you have not blocked the air inlet holes in on the back side of the freezer and that the door lights work on the freezer side.
1helpful
How to resolve issue with Kenmore Freezer #253.21741106 (upright) leaking water and red Temp alarm blinking?
A few things spring to mind.
Failed Defrost timer.
Failed Evaporator fan.
Blocked Defrost drain.
Calling for service is your best bet.
BLINKING FREEZER LIGHT
What is the model number of your unit?
1helpful
Lots of problems
ur coling fan is goimg out,prob ud door sitch is defective' and ur watwer solinoid is not geting voltage, or has gona bad
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Refrigerator not getting cold in Fridge side
No. check this post from right here.
http://www.fixya.com/support/t245665-samsung_rs2556_refrigerator_side_not
Question: was the fridge running when you went to pick it up ?
Was it already on ?
My thinking is that you have the ice build up problem too and that it never thawed. If you unplug it, thawing could take days. Seriously. If you take the inside panel off and get some heat on it
only an hour or so.
You have the exact same model I do, and it works good, just designed poorly. It needs a drain hole on that condensor.
And your fan probably is fine. Do not spend $500.
2helpful
Ice maker not making ice
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
2answers
Samsung RS2545SH Refrigerator
Diagnostic mode will say what any electronic issues are. Check to see if there is, if any, frost build up on the rear panel or ports. If the unit had made any noise in the refrigerator. This unit may have a switching valve for the twin cool, so it could be an issue there.
4helpful
3answers
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
The freezer light is blinking -4
according to the service manuel a blinking light indicates a sensor failure in the section in your case the freezer side but don't panic the unit has an emergency run mode which will keep things at set value till the unit is check in other words like it is now this is a complicated unit so id call for a factory authorized tech to come and check it
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
