2005 Pontiac Sunfire Logo
Anonymous Posted on Sep 27, 2017
Driver's side wheel bearings, greased
It sounds like a squeak as I manoeuvre the steering wheel to the left with any amount of effort from a slight turn to a full left turn. There does not appear to be any grinding at the current time. Can the front driver's side wheel bearings be re-greased or are they completely sealed unit that need to be replaced as a whole unit? Thank you for your time.
Matt O'Donnell
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Sep 27, 2017
Matt O'Donnell
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
2107
Points
52
That depends on what type of vehicle you drive. If the noise is on turns it’s more than likely a bad ball joint or toe rod end
5 Related Answers
Anonymous
  • 107 Answers
  • Posted on Jul 20, 2009
SOURCE: front wheel squeak when making right turns
warped brake rotor have you had it serviced if so the over tightend your lugs causing your rotors to warp... does it pull when you brake?
Anonymous
  • 4803 Answers
  • Posted on Oct 23, 2009
SOURCE: ABS light & trak off light keep coming on.
It sounds like "False Antilock Mode" to me. Your Antilock Brake Control Module "thinks" that you have a wheel locking up. This is probably caused by a bad wheel sensor. You need to scan the module to find out which one.
Testimonial: "Thanks for your help.You have told me more than the "mechanics" I have talked to! I might be on the way to getting this problem fixed."
gordanddar
gord storey
  • 477 Answers
  • Posted on Apr 18, 2010
SOURCE: Car has a grinding sound and a slight vibtation
Not likely the caliper , could be wheel bearing , bent axle , bent rim , steering or suspension part way worn out.
Anonymous
  • 104 Answers
  • Posted on Dec 17, 2010
SOURCE: Drivers side front wheel is grinding anytime while
sounds like a bad hub/wheel bearing assembly
A
Anonymous
  • Posted on Mar 31, 2011
SOURCE: I am having a horrible
I really hate these questions
How do different mechanics come up with
different ideas.
They either talk the talk and test nothing
or you leave with no solution & I ask why?
Have you left the car long enough with specific
directions, as to what was to be done and nothing else ?
If so, then we have a lot of incompetent folks in the wrong
line of work
I have no idea what your issues are
But you have ABS & Trac lights on, and just had a CV axle
replaced. That give me a bad feeling that the ABS Sensor
was damaged
Take this with some doubt,but mechanics just can not
put down the air guns. They could very well have ruined ,
what were good wheel bearings, doing your axle
The ABS issues are part of your vibration & unless you
know all about the condition of your brake rotors and pads
and all the possible years of accumulated rust going on there,
that is more to look at.
Occassional squeaking from front driver-side tire
could be wheel bearing ,could be cv joint could possably be bushings in suspenion.
2007 Pontiac Grand prix GT steering components diagram
Variable Effort Steering System Description and Operation
The Variable Effort Steering (VES) system or MAGNASTEER® Varies the amount of effort required to steer the vehicle as vehicle speed changes. At low speeds, the system provides minimal steering effort for easy turning and parking Maneuvers. Steering effort is increased at higher speeds to provide firmer steering (road feel) and directional stability. The Electronic Brake Control Module (EBCM) controls a bi-directional magnetic rotary actuator located in the steering rack and pinion. The EBCM varies the steering assist by adjusting the current flow through the actuator to achieve a given level of effort to steer the vehicle. The VES system accomplishes this by adding or subtracting torque on the input shaft to the rack and pinion. The main component of the system is an electromagnetic actuator, which consists of a multiple-pole ring-style permanent magnet, a pole piece, and an electromagnetic coil assembly. The VES system uses the ABS wheel speed sensor inputs to determine vehicle speed. When the EBCM senses wheel speed, it commands a current to the VES actuator that is most appropriate for each speed. The EBCM commands current from negative two amps to positive three amps to the actuator, which is polarized. At low speeds, a negative current is commanded, which assists steering. At medium speeds no current is commanded and steering is assisted by hydraulics only. At high speeds, a positive current is commanded, which creates steering resistance. Ignition voltage and ground are provided through the EBCM. The EBCM has the ability to detect malfunctions in the actuator or the circuits to the actuator. Any malfunctions detected will cause the system to ramp to zero amps and steering will be assisted by hydraulics only and setting a DTC.
The Magnasteer® system is a speed-dependent power steering system. The Magnasteer® system provides power assist at varying levels depending on need.
A bi-directional magnetic rotary actuator in the steering gear adjusts the amount of torque (driver effort) necessary to turn the steering wheel.
The Magnasteer® is controlled through the ABS module and varies the torque by adjusting the current flow through the actuator.
The amount of adjustment will be directly related to the vehicle speed. The controller receives speed-related input signals from the vehicle speed sensor.
For more information on Magnasteer® refer to Variable Effort Steering System Description and Operation
Is the vehicle driveable ? The steering wheel is connected to the wheels
DTC C0450 Steering Assist Control Solenoid/Motor/Actuator Circuit
Sounds like it's stuck on full assist .
1helpful
2000 mercury sable ls squeaks in the front when it gets cold, what should i put on the front end joints and stuff? Highly annoying.
If it happens when the steering wheel is being turned left or right when parking, it could be dry tie rod ends. They will have to be replaced and greased up well to get rid of the sound. This happened to my dad's 1998 Ford Taurus.
1helpful
2answers
I have a 2004 dodge neon sxt and when I go between 65- 80 mph it shakes the steering wheel. Plus the right tire squeaks. Could it be the wheel bearing?
Yes. It could be the wheel bearing, but more likely your wheels need to be balanced. As far as the squeaking goes, make sure the ball joints and tie rods are greased (if possible). The squeaking could also be coming from the brakes.
Passenger side sounds like it is rubbing
There is nothing to grease. Someones playing with your head. There was a tech bulletin out, on the steering squeeking. I would flush the power steering fluid. I have a 2004. Let us know from time to time how it's doing
Squeaking Steering!
Sounds like you might have ball joint problems.This usually happens when they are not greased.Some of these models do not have grease zerk`s.If it does then you can try greasing them but they might be plugged with rust.I would grease the whole front suspension.Hope this helps.Good luck.
2helpful
My car makes a humming noise when excellerating and is especcially noisey when turning steering wheel to the left. there is also a continous squeak. my husband put WD40 on the bolt on power steering box...
If WD-40 got on belt, and squeak went away for a while, it may just need a new belt. The humming noise sounds like a worn wheel bearing that should be checked and replaced if needed. If squeak goes away when you push slightly on brake pedal, it may be rotor on same side as wheel bearing making the noise due to slight shifting of rotor because of worn bearing.You can try swapping tires on front from one side to other to confirm it isn't tire problem as well. If noise shifts to other side, then it's a tire.
1helpful
2answers
When i turn the front wheels left or right i hear a loud sqeaking
you need to get grease into pittman arm there is no grease fitting so get a needle fitting for your grease gun and poke thru the rubber ive done twice on 97 f150s and fixed the problem
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
