Cameras Logo
Anonymous Posted on May 07, 2013
My product is a Canon PowerShot 130 IS
Most pictures I've taken are PROTECTED. How can I unPROTECTIVE them?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on May 07, 2013
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10440407
Points
622693
5 Related Answers
leethedeuce
Lee A.
  • 4472 Answers
  • Posted on Jun 13, 2008
SOURCE: how to unprotect the memory card
If I understand correctly what your asking what is the brand and size of the memory card. If I were to take a stab at it right now I would assume there is a lock/unlock switch on the card. Have you had this problem with the card before?
Good luck,
Lee
Anonymous
  • Posted on Sep 18, 2008
the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
  • 102366 Answers
  • Posted on Apr 21, 2010
SOURCE: my card says: card write protected & won't let me take pic's
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Anonymous
  • 11967 Answers
  • Posted on Jul 21, 2010
SOURCE: All the pictures taken outside or in lighted area
Go into the menu and find "reset"...follow the on-screen instructions.
Anonymous
  • 73 Answers
  • Posted on Aug 01, 2010
SOURCE: i accidentally protected a picture
There are 2 ways to do it. Firstly you can format the card - this will delete all images, including protected ones. Second method is to display the image in full frame view mode (or highlight it in thumbnail view) and then press the AE-L /AF-L button. This will remove the protection - or protect an unprotected image.
Hope that helps
3helpful
How to delete protected images
If you want to delete everything on the card, the easiest way is to format the card. This will wipe out all images (and any other data as well) on the card, whether protected or not. The Format command is in the Setup menu. Details on page 32 of the manual.
To delete individual protected pictures, unprotect them first. From the Playback menu select Protect/Unprotect (the key icon). Details on page 84.
2answers
I accidentally "protected" all of
The instructions for protecting/unprotecting images are in the "Protecting images" section of the manual (page 98 in my copy).
The best way to delete all photos on a memory card is to format the memory card. This should be done each time you finish transferring your pictures to a computer, as FixYa is full of people asking how to retrieve pictures from cards that haven't been recently formatted. Refer to the "Formatting Memory Cards" section of the manual (page 22 in my copy).
If you need a manual, you can download one from the manufacturer's web site at
http://gdlp01.c-wss.com/gds/2/0300003042/01/PSA3100IS_3000IS_CUG_EN.pdf
How do you erase protected pictures on powershot A 560?
Unprotect the picture first. Press the playback button (the right-pointing triangle), then select the key icon from the menu. Details are in the "Protecting images" section of the manual (page 71 in my copy). If you need a manual, you can download one from
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a560#BrochuresAndManuals
2helpful
How do i unprotect a picture? I accidentaly protected it and i want to delete it.
I'm glad to provide the instructions to cancel protection applied to the images. Please read the below instruction carefully to get the steps to unprotect an images.
Thanks for understanding. Please let me know if you require further assistance.
3helpful
2answers
I dont know how to delete a protected picture off my canon power shot a470 camera. Can you help?
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
Cannot delete videos from Canon A480 camera. I try to delete and it says protected. thanks.
Unprotect it first.
Full details are in the "Protecting images" section of the manual (page 92 in my copy). If you need a manual, you can download one from the manufacturer's web site at
http://gdlp01.c-wss.com/gds/7/0300001857/01/PSA480_CUG_EN.pdf
I can't find the manual for my didital ixus 700 and need to delete some photo's but they have been proteced, i don't know how to remove the protected status?
Here's the manual (free to download):
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/IXUS%20700-_E
Protection / unprotection of pictures is dealt with on page 130.
Note that FORMATTING a card will delete ALL pictures (irrespective of protection).
Hope this helps
Remove protected pictures from camera
go into where you protected them and click on pic and the scroll down and hit unlock or unprotect and that will remove the protection on the photo.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
