Hi bh , heres what to do . star coin 3 : Before you reach the final tube of this underground
stage you'll move across a see-saw platform. Wait on the left side of
the platform to raise the opposite end, then quickly run up the slope
you've created (jumping helps go faster!) so that you can leap off the
right edge of the platform and jump onto the bricks above the
rest of the stage. Mario will appear mostly off-screen. Continue
running right and you'll find a hidden tube and the last Star Coin just
below it.
here is a link to the best walk thru , i set the link to world 1 so scroll down the page to level 2 and see the goodness ...
http://guides.ign.com/guides/682879/page_3.html
good luck
J5
On the last werid log, try to get up on the celing and u will get a sprise
SOURCE: where is the 3rd gold coin in world 1 level 2
go to the final platform that sways up and down right before the warp pipe that takes you to the flag pole. wait until the platform goes up on the right. jump on the rocks on the top of the screen,then dash. then you will see the 3rd coin.
SOURCE: World 6, Tower 1 (after 6-2), Last gold coin
hi liz , that is a tuffy , i tried hundreds of times , your spossed to be able to jump the dry bones , then get a running start and jump to the right wall , then wall jump back to the upper part of the left wall then to the right and back to the left where you will be at the warp pipe that leads to the 3rd coin , how ever i have not been able to accomplish that in 200 tries , so i got a mini mario in my circle to use when i get there , get to that last door area and mini will do the wall jump just fine , go up the warp pipe and hold on , 4 spiked bars from all directions , dont panic , wait for the cycle , jump to the 1st landing ,then up 1 more to the right and back to the coin , stop at as far left as you can when you get the coin and duck , wait for the next cycle then return the way you got up there and go back down the warp pipe , go back down to the door that dry bones is guarding , enter the door , now you have to stomp bowser jr 3 times as a mini , its tuff but not as hard as wall jumping .
here is a great walk thru link that helped me complete the game 3 times .
http://guides.ign.com/guides/682879/page_21.html
the link i set at world 6 so scroll down to tower level , and see good pics of what to do .
good luck with the game , as hard as some levels are don't give up .
the best tip i could give is to go back to world 1-1 after each level complete and get 2 flowers and extra 1 ups before going into your next level so you are prepared .
J5
SOURCE: In World 8 second castle, cannot figure out how to
There is no ropes in the second castle but if you are referring to the first BIG castle. here's your solution...
You only get one shot at it. if you die and you cross half way point, you are going to have to start another level and exit out of it, in order to start from the begging again. After crossing all of the fire stuff and what not and getting to the third platform, where the second walking dead turtle is. is where the fun and your skills will be put to the test. hit the red square just above you until the "brown" moving platforms on your far right (not the one that is right below you) is on top. There is three places where it could be. just make sure that is on top. Get on it. if you stay on the far left, you'll get the second coin, no problem. jump onto the fourth platform. and DO NOT hit the red square. There should be a "brown" platform on the bottom. If there isn't you have to restart, your game. you did something wrong. After this you know the drill and you'll end up on the fifth platform. Where there'll be a coin and a bonus and the midway point. if you die past this point. You'll have to restart the entire level. Get to the Big doors and this time the "brown" platform that you need will be waiting for you. Make sure you duck right away otherwise you'll get knocked down. The rest is up to you. Once again Don't DIE! good luck.
SOURCE: cannot get the last gold coin on super mario brothers ds lite
yes you can get that last coin in world 7 at the last castle, just wall jump! you have to have perfict timing but yea wall jump! you have to do it before that green floor starts to break up. TIP go as small mario, and have a mega mushroom saved. used the mega shroom when fighting the last guy. i have all the coin's in the game!!! good luck!!!
Thank you for your help. It helped alot, now if I could just do it!!!!
Bethany
