I checked the sound card in my computer and it shows songs on it. When I put the card in the player, it says "No songs". I downloaded the songs by putting the card in my computer. I don't have the USB cable that came with the player. Is there any way to fix this without the cable?
Hi sfarmer1983...
Plug your SD card into an SD card reader...the plug the card reader into the computer.
The computer will recognize the card reader and open a window...you will select "see files"...
Highlight the songs and put them in Windows media Player...plug your mp3 player in while the computer is running and Media player is running...Media player will recognize your mp3 player
Highlight your songs in the SD card reader...drag and drop the files to Media player...
Please take time to rate me
when you put the songs on your sd card,did you make sure that you drug them to the music folder on the sd card,if you didn't they wont show up..the folder will say music or sounds.
If you mean that the songs don't show up on the computer screen, then you probably need to change the USB MODE setting on the Clip. To do this, disconnect the Clip from the computer, then scroll to SETTINGS. Select Settings, then scroll to USB Mode and select it.. (If your Clip is very old it might not have a USB Mode listed under SETTINGS. If this is the case you should update your Clip's Firmware from the sansa website). Older computers recognize the MSC Mode while newer ones should recognize either mode. (except XP Professional doesn't seem to recognize the MTP mode). Songs entered in one mode won't show up on the computer if you're in the other mode. If you mean that the songs aren't showing up on the Clip's own screen then this solution probably won't help. By the way, I've never had any luck with the "auto detect" mode.
More than likely your Zumo will not recognize cards larger than 2 gb. This is not a problem with your device. They are not designed to use larger cards.
There are 3 ways to solve your problem, but all of them are rather kludgy. This is an old player and the integration of the microSD card is not done very well. I believe with the newer players these sorts of issues are not problems. Anyway, here are your 3 possibilities:
1) You can load your music directly onto the card before you put it into the player. Most cards come with an adapter that lets them fit into slots that are for regular SD cards. So if your computer has a slot for an SD card (or if not, you can plug the card into a card reader and then plug the card reader into the USB port on your computer) then you can copy and paste mp3 files onto the card. This is a drag because you can't use Windows Media Player to do this, but instead need to open the folder where the MP3 files are and then copy and paste them onto the card. But it works
2) This is slightly easier. Before you connect the Sansa player to the computer go to the settings part of the main menu and then select mode. You should see two choices. One is MTP and this is the setting you want if you are using the player with Rhapsody service. The other setting is MSC and this lets your computer recognize the Sansa player AND the microSD card. Once you have selected the MSC mode, then you can connect the player to your computer. When you look at the drives on your computer, you'll see 2 new drives. One is the Sansa 280 and the other is the microSD card. Once you see those, you can copy and past MP3 files right onto the card (and/or onto the Sansa). Again, you have to go the folder where your MP3 files live and cannot use WMP to do this
3) I haven't tried this, but others say that a free program called rockbox (www.rockbox.org) let's all this work much better. It sounds complicated, as it puts kind of a new operating system on your Sansa and it may not be reversible, so proceed with caution, but some people love it.
Hope that helps
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200 - verify the version of the player. To check, go to SETTINGS > INFO.
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards NOTE: Firmware is not interchangeable.
Try transferring the songs directly to the music folder of the player and check if they would be recognized by the player. And make sure the Bitrate is in the range of 120-320kbps .
Try updating the firmware, you can download it from the RCA Website (http://support.rcaaudiovideo.com/).
If your computer doesn't recognize the player, you'll have to turn it
off, remove the battery and keep "PLAY" pressed for 10 seconds while connecting it to the
USB port, then update the firmware.
