I have Pulsar V744-X004, The watch displays both day & date. The day is stuck between 2 days. I can read half of ..DAY and half of MON.. How can I adjust watch to display MONDAY?
Phil
Based on the information you've provided, it sounds like you have a Pulsar brand watch. The numbers "160622" and "V533-8850" are likely the watch's serial number. The "M" inside of a box is likely a hallmark or hallmarking, which signifies that the watch's gold content meets a certain standard. The watch has a gold and silver appearance, with a gold face and gold hands, and has a display on the face for the day and date.
Pull the stem out to the time set level. Turn the hand around until the date change. Now push the stem back in, pull to date set level and change to current date. Now the watch is at midnight for that current date. Note you can set to current time of day. The Watch will automatically change to correct date for next day at midnight as it should.
Setting the day on your Timex analog watch is a simple process. Please follow the steps below.
Multi-Function Models
1. Pull the crown on the side of the watch case all the way out. This will be position "C," with position "A" having the crown pushed all the way in and position "B" being pulled out halfway.
2. Turn the crown clockwise until the correct day appears on the small face displaying the day.
3. Press the crown all the way in, to position "A."
Chronograph Models
1. Pull out the crown on the side of the case to position "B." This is halfway out. You will feel a slight click when the crown is in position "B."
2. Turn the crown clockwise until the watch face shows the correct day.
3. Push the crown all the way into position "A" to complete the process.
Both the time and the date are set via the winding stem. To set the date, pull out the stem to the first "click" and than turn it and watch as the numbers change. To set the time, pull out to the second "click" and then turn to set the time. Some watches have a screw-down stem crown. If yours does, simply unscrew it by rotating in a counter-clockwise direction until it releases and pops out slightly.
If your watch has a day calendar function it is important to not attempt to set the hour or change the date if the current reading is between 10 PM and 2 AM. If you do, there may be some damage to the advance function responsible for moving the calendar.
The easiest way to set the time and day is to advance the date to the day before the current one. Then pull out the stem and advance the hours until the date clicks over. That is midnight and as long as the current time isn't between 10 PM and 2 AM, you're good to go.
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
You have to adjust the date every February (28 or 29 days), April, June, September and November (each 30 days). Self adjusting calendars are called Perpetual Calendars and this feature is quite expensive, especially in mechanical watches. Your watch has calendar ring with 31 days printed on and the simple calendar mechanism which is changing dates from 1 to 31 inclusive,day after day, so, when the 30-day month is ending and there is no 31st date to follow, your calendar is showing 31st anyway,instead of 1st of the next month. This is when you have to adjust date. Now about the date adjusting. If you pull out crown gently, you will notice there are two clicks (positions), not just one. So the first click, when crown is not pulled out fully, is exactly for day/date adjustment. If you pull the crown further out, watch is in hand adjustment mode. Try it carefully and you will find out the right position.
Rate me, please.
The watch does not have a "perpetual" clock so it does not know what month it is in. It will treat every month as a 31 day month, so you will have to re-set the date anytime a month is not 31 days.
If you appreciate me answering this for you then please rank this
solution as "fixya" or at least "helpful" as what I have said
will solve your problem. :-)
Had Pulsar analog watch. Couldn't set either day or date properly due to being unable to signify AM or PM. When days changed one or the other would be 12 hours off.
""googled" adjusting Pulsar watches" and found site which explained how. You set day of week and date to previous day and date and then move watch time ahead until day and date are correct. Then set watch time. Seems to work.
