Kenmore 73952 Gas Dryer Logo
Posted on Apr 16, 2017
Trouble starting Kenmore Dryer
I have a Kenmore 70 Series Dryer Type 180-00 / 66712694. The dryer won't start unless I hold the power button and turn the timer as the button is held down. When the timer reaches certain areas on the dial, the dryer will start, but sometimes it takes just the right position to allow me to let go of the push button so it continues. After that, it works fine until the next load. It does this in the auto dry or the timed dry option. It heats fine, etc. I am thinking it is a faulty timer, but would like a second opinion since the timers are close to $100. Thanks for your input!
5 Related Answers
Anonymous
  • 525 Answers
  • Posted on Jul 14, 2008
SOURCE: Kenmore Electric Dryer Quit Spinning
Based on the information provided above, I am unable to provide a positive solution to your issue. The model number is incomplete. I have provided some common solutions to help guide you in your search.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information. This link will take you to the belt diagram page.
http://www.repairclinic.com/0079.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Anonymous
  • Posted on Oct 06, 2008
SOURCE: Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Anonymous
  • Posted on Dec 19, 2008
SOURCE: my kenmore 70 series dryer quick working
My wife was cleaning the top part of the dryer, and took off the knobs to clean them and the dryer will not start up and not run at all. where do I start to problem solving?
onthejob5130
onthethejob1
  • 640 Answers
  • Posted on Dec 28, 2008
SOURCE: Kenmore 70 Series Gas Dryer doesn't shut off
replace timer
tzweeb
Tom Zwiebel
  • 318 Answers
SOURCE: Kenmore dryer 70 Series doesn't shut off, timer continues to run
there are 2 different kinds of units made back then.
one has a push to start button that could have a stuck contact causing the unit to think you are pushing the button and want it to run again.
the other could have a stuck motor switch and thats not available separately. you would have to replace the motor. try to clean any lint out of the motor if you have that type. use compressed air to blow the lint out of the motor. it usually works to get the lint out and it can cause the switch to stick.
My Kenmore 80 series dryer won't stay on unless I
Aha!
You are going to make me guess!
I am guessing you have to hold the start button down.
So.
Try a new start button first.
If that does not fix it, replace the timer/control unit.
God bless your efforts.
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Kenmore 70 series won't start I have check circut breaker and plug
heatman101
Sep 14, 2011 • Dryers
Kenmore 90 series dryer, the button to turn it on won't stay depressed unless you stand there and hold it down. is there a part i can get for it to fix it or should i just get a new dryer?
heatman101
Aug 11, 2011 • Dryers
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Kenmore 70 series dryer makes buzzing noise and stopped working
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
1helpful
I have a Kenmore Series 70 dryer wont start, just hums
Check for correct voltage at the terminal block on the back of the dryer, where the power cord attaches to the dryer.You should be getting 220/240 volts, check by way of a voltage tester.
If the voltage is correct, then could be the motor capacitor or the motor itself, or start button?
Good Luck !
1helpful
Kenmore 70 series dryer has power just wont start when push the button is it the start switch?
could be the start switch or it could be the safety switch in the bottem of the dryer that turn the dryer off incase the belt brakes.
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
