Witout the device getting recognised it becomes impossible install the firmware.kindly help me with this.
I fixed this problem myself. You have to retool the Archos. First you have to go to settings and calibrate the touch screen and then the Archos itself will show up on the computer.
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up, just pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and your archos will be back to normal
