When turning on machine and pushing the rinse button the machine goes through the cycle. Towards the end of the cycle the mechanism sounds like it is straining. It all slows down nearly to a stop then finishes. I'm afraid that at some point it's going to wear out parts or actually break. Is there anything other than a cleaning cycle to remedy this? Should I look inside?
It can be that the grounds blade is loose, This will jam the brew unit when it`s finishing up. This is actually easy to fix, but you need an ovalbit to loosen the screws behind the watertank. Then you have to reatatch the groundsblade to the brew unit. But i recomend you to contact the local servicedepartement for Jura machines. They can help you with this in five minutes.
Make sure dial is switched
to 'off'. Unplug your machine, then plug
it back in. Hold down the rinse and delay buttons with one hand. With the other
hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just
the start button flashes. If if doesn't work, do it again.
To get the clothes out if
you are having trouble, open door manually. Near the bottom of this cover is a small
hole. Insert a piece of wire into this hole, and push in gently. While pushing,
turn the cover clockwise, it will came off. The door release is a narrow white plastic
strip hanging down on the right; Pull down on this strip while pushing in on
the door, the door lock will release.
Click helped if helped.
