Check youtube my friend, there are great instructional videos there.Remove wheel from front forks, release any air from tyre, using 2 plastic tyre removal tools to remove tyre. Further instructions will be found on youtube.
? 0:58
https://www.youtube.com/watch?v=xFx7UXyjW4Y
Dec 11, 2011 - Uploaded by Bicycles Online
When I went to reinstall my wheel my brake pads were stuck together and I don't know how to get them apart ...
? 7:31
https://www.youtube.com/watch?v=BNwa0lONtbc
Jun 30, 2012 - Uploaded by cjhoyle
This is a quick tutorial showing how to remove the front wheel of a bike. ... Getting the lightly tightened other nut off shouldn't be aproblem.
Remove brake caliper mounting screws from where they mount on the front forks. Slide caliper off brake disc and secure caliper
out of the way. Do not operate the front brake lever with the front wheel
removed or the caliper pistons may be forced out. Reseating the pistons requires disassembly of the caliper. On models with dual disc brakes, remove both calipers.
Remove axle nut lockwasher and flat washer from axle on left side of vehicle.
On right side of vehicle, loosen nut on pinch screw. Pull axle out of hub while supporting wheel.
Remove spacer and front wheel assembly.
Keep track of where each of the different size spacer went so you can put the back in the same order when reassembling.
For reinstall, you should get a manual as you will need to get torc specs. and other spacing and assemble instructions.
To replace hub/bearings on a Chevy sprint, Do all the obvious things; raise car, etc.etc. with the wheel off, remove caliper and support with wire, string. remove strut bolts, outer tie-rod bolt and tie-rod, remove ball-joint bolt, you should be able to tilt the knuckle out of the way enough to drive out the ball-joint stud (o install reverse the removal instructions. I have owned and self repaired a total of five sprints.
Item
Part Number
Description
Cotter Pin
Nut Retainer
Insulator
3B477
Front Axle Wheel Hub Retainer
5
1195
Front Wheel Outer Bearing Retainer Washer
6
1104
Wheel Hub
7
1107
Lug Bolt
8
3K050
Snap Ring
9
3123
Front Wheel Bearing
10
2K004
Front Disc Brake Rotor Shield
11
3130
Front Wheel Knuckle
Wheel Hub, Wheel Knuckle and Wheel Bearing
SPECIAL SERVICE TOOL(S) REQUIRED
Description
Tool Number
Tie Rod End Separator
T85M-3395-A Removal
Raise and support the vehicle.
Remove the wheel (1007) and tire assembly.
NOTE: It is not necessary to disconnect the front brake hose (2078).
Remove the disc brake caliper (2B120) and suspend it with mechanic's wire out of the way. Refer to Section 06-03 for the removal procedure.
Remove the front disc brake rotor (1125).
Remove and discard the cotter pin.
Remove the nut retainer and insulator.
Remove the front axle wheel hub retainer (3B477) and the front wheel outer bearing retainer washer (1195).
Remove and discard the cotter pin from the front suspension lower arm ball joint (3050).
Loosen the front suspension lower arm ball joint nut until it contacts the front wheel driveshaft joint.
Strike the front wheel knuckle with a hammer while pulling down on the front suspension lower arm (3078) until the front suspension lower arm ball joint separates from the front wheel knuckle.
Remove the front suspension lower arm ball joint nut.
Remove the front suspension lower arm ball joint from the front wheel knuckle.
Remove the tie rod end nut.
Use Tie Rod End Separator T85M-3395-A to separate the tie rod end (3A130) from the front wheel knuckle.
Remove the front brake anti-lock sensor bolt.
Remove the two front shock absorber-to-front wheel knuckle nuts.
Remove the two front shock absorber-to-front wheel knuckle bolts.
Remove the front shock absorber (18124) from the front wheel knuckle.
Use 2-Jaw Puller D80L-1002-L, or equivalent, to separate the front wheel driveshaft and joint (3B436) from the front wheel knuckle.
Remove the front wheel hub, front wheel knuckle and front wheel bearing as an assembly from the vehicle.
If necessary, match mark and remove the steering stop bolt and steering stop bolt jam nut from the front wheel knuckle.
Installation
Position the front wheel hub, front wheel knuckle and front wheel bearing as an assembly on the front wheel driveshaft and joint.
Install the front wheel knuckle into the front shock absorber.
Install the two front shock absorber-to-front wheel knuckle bolts.
Install the two front shock absorber-to-front wheel knuckle nuts. Tighten the front shock absorber-to-front wheel knuckle nuts to 113-123 Nm (83-91 lb-ft).
i have the graco quattro tour sport, i put it together & noticed the swivel lock was missing! I have to take the wheel back tonight but i had already put it on the pram! after reading 'Adorough's' comment i had good look at the wheel to figure out how to get it off. 1) fold the pram up and stand it so the front wheels are up. 2) if you look round the back of the front wheel you should see a round 'pin' which is set back, you well need a pen or something pointy to press the pin in & pull the wheel! That worked for me.
