Video Game Consoles & Games Logo
Posted on Mar 16, 2009
Memory stick 4GB but when connect USB Cable show free space 3.9mb
I want to download games to my PSP the problem is my memory stick contain 4GB but when i connected USB cable for downloading it shows that my memory stick is only 3.95MB. I already formatted my memory stick
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
82
Points
THIS IS DARELL: MAYBE iT has a virus or something?
Joseph Barakat
Level 1:
New Friend:
  • Posted on Sep 22, 2013
Joseph Barakat
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
82
Points
After formatting a memory stick, the window's system leaves a hidden file which it may use as a "readyBoost' device. Open file manager and right-click on the memory stick and look at properties.
2helpful
How to get psp games
Try these steps : 1.
Check to see if you have the right firmware. Firmware is the proprietary operating system the PSP requires for functioning. You need Firmware 1.0 or 1.5 to download free games on a PSP. These versions allow you to play PSP homebrews; later versions have protections that avoid use of non-commercial PSP games.
To check your PSP's firmware, press the PSP's "Home" button. Scroll down and select "Settings." From there, select "System Information." The firmware information can be found in the section where it says "System Software." If this section has the number 1.0 or 1.50, you'll be able to play PSP homebrews. If the number is higher, you won't be able to download free games on a PSP.
2.
Format a PSP memory stick. The size of the memory stick doesn't matter since most PSP homebrews are relatively small. Insert the memory stick into the slot located on the left side of the PSP, where the directional buttons are. Pop open the cover and slide the memory stick in, making sure it's face up and follows the direction of the white arrow.
Press the "Home" button and go into the "Settings" section. Scroll down and select "Systems Settings." In the next screen, continue scrolling down until you can select "Format Memory Stick." The PSP will ask you if you want to format the memory stick. Answer "Yes," and the PSP will format the memory stick within just a few seconds.
3.
Download free PSP games onto your computer. Sites like PSP Brew, UR PSP and PSP-Homebrew.eu contain tons of free PSP games. And the downloading process is pretty much the same. You either select an option to download, or you right-click on the file and use "Save As" for downloading. Visit the sites to gain a better understanding; links are provided at the end of this article.
4.
Unzip the files. Usually, when you download free PSP games, you receive files in a compressed (or zipped), format. This allows a developer to send larger files without the hassle of breaking them up into pieces. However, before you can use these games, you will have to unzip them so you can have access to the individual files.
To unzip files, you need to use an unzipping utility. Windows comes with one, and it's relatively easy to use since you just select options from a Wizard. But if you prefer something more sophisticated, consider using WinZip, for the PC, or Stuffit, for Macs. Both of these programs can be downloaded free, though the legal version of WinZip only offers a 30-day trial. Either way, unzipping is as simple as selecting "Extract" and entering in the name of the file you want your games in.
5.
Connect your PSP to the computer via a USB cable. Make sure you place the smaller end of the USB cable into your PSP. Place the larger end into any of the USB ports available on your computer.
6.
Switch to USB mode. The PSP cannot communicate with your computer unless it is in USB mode. This is accomplished by pressing the "Home" button, scrolling towards "Settings" and then selecting "USB Connection."
7.
Transfer the games onto your PSP. This step is the heart of downloading free games onto your PSP, and it is simple. With your PSP connected to your computer, take whatever games you plan on downloading and place them into the PSP > GAME folder. If this folder doesn't appear automatically, you can create one by "right-clicking" in the PSP directory and then entering in the name "Game."
8.
Run the games you downloaded. After you have installed the desired games onto your PSP, disconnect the device from your computer. In the main menu, scroll to the "Game" section. Select the "Memory Stick" option. The PSP homebrews you downloaded will be contained here. Highlight one of them and press "X." Assuming the homebrew is coded properly and you have the right firmware, it should run just like a commercial PSP game.
In case of any problem please revert back
tip
How to Download Games on a PSP for Free
1.Check to see if you have the right firmware. Firmware is the proprietary operating system the PSP requires for functioning. You need Firmware 1.0 or 1.5 to download free games on a PSP. These versions allow you to play PSP homebrews (later versions have protections that avoid use of non-commercial PSP games).
To check your PSP's firmware, press the PSP's "home" button. Scroll down and select "Settings." From there, select "System Information." The firmware information can be found in the section where it says "System Software." If this section has the number 1.0 or 1.50, you'll be able to play PSP homebrews. If the number is higher, you won't be able to download free games on a PS
2.Format a PSP memory stick. (The size of the memory stick doesn't matter since most PSP homebrews are relatively small.) Insert the memory stick into the slot located on the left side of the PSP, where the directional buttons are. Pop open the cover and slide the memory stick in, making sure it's face up and follows the direction of the white arrow.
3.Download free PSP games onto your computer. Sites like PSP Brew, UR PSP and PSP-Homebrew.eu contain tons of free PSP games. And the downloading process is pretty much the same. You either select an option to download, or you right-click on the file and use "Save As" for downloading.
4.Unzip the files. Usually, when you download free PSP games, you receive files in a compressed (or zipped), format. This allows a developer to send larger files without the hassle of breaking them up into pieces. However, before you can use these games, you will have to unzip them so you can have access to the individual files.
To unzip files, you need to use an unzipping utility. Windows comes with one, and it's relatively easy to use since you just select options from a Wizard. But if you prefer something more sophisticated, consider using WinZip, (for the PC), or Stuffit, (for Macs). Both of these programs can be downloaded free, though the legal version of WinZip only offers a 30-day trial. Either way, unzipping is as simple as selecting "Extract" and entering in the name of the file you want your games in.
5.Connect your PSP to the computer via a USB cable. Make sure you place the smaller end of the USB cable into your PSP. Place the larger end into any of the USB ports available on your computer.
6.Switch to USB mode. The PSP cannot communicate with your computer unless it is in USB mode. This is accomplished by pressing the "Home" button, scrolling towards "Settings" and then finally selecting "USB Connection."
7.Transfer the games onto your PSP. This step is the heart of downloading free games onto your PSP, and, it is simple. With your PSP connected to your computer, take whatever games you plan on downloading and place them into the PSP > GAME folder. If this folder doesn't appear automatically, you can create one by 'right-clicking' in the PSP directory and then entering in the name "Game."
8.Run the games you downloaded. After you have installed the desired games onto your PSP, disconnect the device from your computer. In the main menu, scroll to the "Game" section. Select the "Memory Stick" option. The PSP homebrews you downloaded will be contained here. Highlight one of them and press "X." Assuming the homebrew is coded properly and you have the right firmware, it should run just like a commercial PSP game.
2answers
Where can download free psp games
So you just got your new PSP and you want to download games but you're not sure what to do or where to go? Well this article will show you how download games to your PSP.
First you will need:
Sony PSP with firmware 1.0 or 1.5
PSP Memory Stick Pro Duo
1. Go to the website and pick the game that you want to download.
2. Download the game to your computer making sure that it will work with the version of firmware that is on your PSP player. Make sure the file ends with PSP
3. Insert the memory Stick into your PSP player
4. Connect the PSP player to your computer via the USB cable
5. Copy the game onto your PSP player making sure to place them under the "PSP", "GAMES" folders on your memory stick. If these folders don't exist on your memory stick you will need to create them.
That's it now you are ready start playing your games.
I am adding a link for free download...
http://www.pspmaniaonline.com/
you can also search for many other sites..just google for free psp games..
Iwan to download
A LINK FOR FREE GAMES...
How to download psp games?
Free psp games
I am adding linkS for free download...
http://www.freeforpsp.com/
Why iam download free game for psp
How to put games on my psp?
2answers
How can i download free psp games ?
Follow these steps to Download Games on a PSP for Free :
1.
To check your PSP's firmware, press the PSP's "home" button. Scroll down and select "Settings." From there, select "System Information." The firmware information can be found in the section where it says "System Software." If this section has the number 1.0 or 1.50, you'll be able to play PSP homebrews. If the number is higher, you won't be able to download free games on a PSP.
2.
3.
Download free PSP games onto your computer. Sites like PSP Brew, UR PSP and PSP-Homebrew.eu contain tons of free PSP games. And the downloading process is pretty much the same. You either select an option to download, or you right-click on the file and use "Save As" for downloading. Visit the sites to gain a better understanding.
4.
5.
6.
7.
8.
3answers
I have a memory stck inserted i formatted it on my psp
that is it . there is no enough space for your demanded progress . that means you should buy more space next time . rate please !
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
