Question about Armitron Watch
Need instructions for setting armitron 40/6735
Cannot set day or date
  • medha1 Apr 27, 2009
    can't set time, date or anything.
    Went to amatron web site for instructions, but this model not listed.
    help!!!
This should help with the 4 buttons:
Push the button Lower left and hold it for 2 seconds and you will see a number flash. This is for the alarm setting.
Push the same button again and a new screen with the time comes up and the seconds are flashing.
Push the top right button again and the minutes will be flashing.
Push the top right again and the hours will be flashing
Push the lower right one time and the time moves ahead 1 hour
Push the lower right again for the next hour and the time moves again. Do this as many times as you want to change the hours. Each time you reach 12:00 the screen will change the “A” and “P” to tell you if you are in AM or PM. Time.
You can set the minutes in the same way as you do the hours by pushing the lower right (set) button. The when done push the lower left to stop the set-up
After you set the time or the alarm, push the lower left button again to stop the set-up.
Posted on May 15, 2009
SOURCE:
Setting day and date on armitron 40/8189 watch?
Google (armitron)(40/8189)(manual) without parens to get instructions.
Jan 25, 2017 | Armitron Watches
How do you set the time on an Armitron 165 wrist-watch?
Hi wtgillo,
Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
I would be more than glad to give you details on how to, Please see steps below.
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
  • After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Have a nice day,
mvincentc
Apr 21, 2011 | Armitron Watches
Watch instructions for Armitron m721 (49/1009 GP) need to set time and date
Hi mandardani,
You can change the time and day of your Armitron watch by following the steps below.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
Jan 05, 2011 | Armitron 40/8125BLK Digital Sport Watch
How do i set the time on a armitron 45/6975 watch i lost instructions
Hi an_stocker0,
There is two pulls to set the time and date .First pull is for the day / date wind it in order to choose the right date number and second pull is for the time wind it until the desired time comes out. For better understanding follow this link for more information and instructions below. Feel free to ask whatever the results.
http://www.armitron.com/docs/Automatic%20Manual.pdf
Hope its may helps;
Regards, VOTIT
Dec 10, 2010 | Armitron Two Tone Sports Watch
How do i set the time and date on my watch?
This is direct link to all ARMITRON watch manuals/instructions: http://www.armitron.com/watch_instructions.asp
or
You can also try with this approach. This is for Armitron WR 330,but i believe this could also help you.
The following labels are on the inner ring of the watch; I've given their positions relative to where numbers would be on the face of an analog watch.
"ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
To set the time, date, and day of week:
Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
Press the ""ST/STP" button to change what you want to set. The options appear in this order each time you press the "ST/STP" button: minutes, hour, month, day, day of week.
Use the "ADJ" button to change the value of the setting.
Touch "MODE" to save the settings and return to time mode.
Thanks for using Fixya. Please rate the solution.
Nov 06, 2010 | Armitron 165 watch
How do i set the day, date and time?
Thanks for contacting FIXYA.<br /> There is a link on Armitron that you can download manual/instructions direct. It can explain better then anything I can write here! Best regards.<br /> <br /> <a href="http://www.armitron.com/watch_instructions.asp">http://www.armitron.com/watch_instructions.asp</a>
Aug 24, 2010 | Armitron Calendar Date with Square Black...
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 | Watches
How to set date and day on armitron 6p29
Go to the Armitron web site "armitron.com" and select "support" from the menu across the top. Scroll down the watches illustrated and choose the one that is similar to the one you have and download the instructions.
Jan 20, 2010 | JCPenney Armitron Men's Steel Blue Dial...
Setting time and date
I found this document to help me. It is from Armitron. My watch didn't look exactly like the one shown, but the instructions still worked.
http://armitron.com/WatchPDFS/ArmitronLadiesDigital.pdf
Aug 08, 2008 | Bulova Watch
Armitron Watch Logo
746 people viewed this question
Top Armitron Watches Experts
Arturs Kalnins
Arturs Kalnins
Thomas F. Schneider
Are you an Armitron Watch Expert? Answer questions, earn points and help others
