Have you tried adjusting the contrast within the sky menu. go to services and alter the settings from there, maybe change the outout from rgb to cyan/red/green.
What does a dvd look like played on it? If it's the same then there is something wrong with the TV. If a dvd looks good - no color problem - then it's the sat box that needs replaced.
How is it with standard channels ie terrestrial do you get a good pics or try to connect separate dvd player to find out if the pics are ok there need to find out if the sky receiver is faulty or not need all these information before advicing you await your answer
first..check your connections at the back of the tv..usually if your running a RGB component connection...if one of the wires is loose..it causes the pic to be red..or green..or something like that...if that doesn't work..run your dvd player..and switch the input to dvd..if it is still green..then you will have to remove the back and reseat the LVDS cable...if that doesnt work...replace the Ssb board....good luck
thanx it working know
