Yahoo YHT-630 System Logo
Posted on Mar 16, 2009
Error No. 40402
I am unable to delete my contacts from Address book after deleting them from contact list. The legend showing "The last Address book action did not succeed (error NO. 40402)" comes up
Hameed
  • Anonymous Mar 17, 2009
    I want to change a contact name and...same 40402...
  • Anonymous Mar 20, 2009
    i hate
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
136
Points
Hiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
1helpful
Want too delate a name from yahoo address book/error code 40402
This is a yahoo server error code
It can happen if you try and try and amend contacts from your friends list before your address book
Go to yahoo mail page > contacts > address book >check box next to contact to be deleted > delete
Open Messenger.
Right click on contacts avatar > delete
I cannot delete several of my messenger contacts even though i deleted from my mail address book. when I try to delete them, I get the following error message: The last Address Book operation did not...
Seems Error Code 40402 pops up when trying to remove them while in your Yahoo Instant Messenger list first.
Glitches and Updates!!! Here's a work around though.
You will need to go to your Yahoo Email Account and delete the contact's name there first.
1. Click Contacts from your Email page to open your list of Contacts.
2. Go to the one you wish to remove and check the box next to it.
3. Go to the top of the list and click the Delete button.
Go to Yahoo Instant Messenger, right click the name and select Delete from the drop down menu.
Error code 40402
[Solution # 1]
You will need to go to your Yahoo! Email Account and delete the contact's name there first.
1. Click Contacts from in the toolboxt to open.
2. Go to the contact you wish to remove and click the box next to it.
Go to Messenger. When your list of Contacts opens, right click next to the name you wish to remove and select Delete from the drop down menu. The contact will be removed here also.
Error Code 40402 pops up when trying to remove a name while in your Yahoo Instant Messenger list first.
[Solution # 2]
Quit the program, then delete the contents of the “Cache”-folder located here:
c:/program files/Yahoo/Messenger/Cache
That usually solves a lot of problems, that occur all of a sudden. Try that and see if it works
[Solution # 3]
most probably a registry error - if you do not have a registry cleaner try downloading the free version of ccleaner from filehippo
once its downloaded select 'registry' from toolbar on left hand side and run 'scan for issues' followed by 'fix selected errors' if errors are detected
use microsoft 'one care' for further check
Hope they could help you
Good luck
Fix error 40402
[Solution # 1] You will need to go to your Yahoo! Email Account and delete the contact's name there first.
[Solution # 2] Quit the program, then delete the contents of the “Cache”-folder located here:
[Solution # 3]
Hope they could help youGood luck
1helpful
When i try to write something into "contact details" i receive the following error message : The last Address Book operation did not succeed due to a server error (Error Code: -40402).
If you are trying to delete a contact, delete them from your email address book first. This error usually comes up when you try to delete a contact from messenger first.
13helpful
7answers
Yahoo Messenger List/Address Book
I have since found out that you have to actually go into your contacts under yahoo mail and delete them from that list, then it deletes them from your messenger. Found this solution on another website. Hope this helps anyone else who is having that problem.
2answers
Yahoo messenger list
This looks to be a problem with Yahoo itself.
Try writing to yahoo technical team.
Link as below.
http://help.yahoo.com/l/us/yahoo/messenger/contactus/contactus-01.html
2helpful
On yahoo messenger, am trying to delete someone from my address book but am coming up with server error 40402. Any ideas?
Try deleting the contact in your YahooMail contact list and not your YahooMessenger list. Both YMessenger and YMail use the same addressbook. So whatever you do in one is reflected in the other.
Top Yahoo Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Yahoo Audio Player and Recorder Expert? Answer questions, earn points and help others
