I am able to connect to GPRS after setting i dail
using AT command
i.e ATD[<*99***1#>][I][G][;]
now i want to send a mail to yahoo from hyperterminal 1st to t290i handset and then to yahoo
how it'll be done could any body tell me
how to write mail and than send it.
SOURCE: gprs settings and mms settings airtel prepaid connection
I think you are asking for the phone settings for airtel gprs. Sinceyou haven't mentioned whether you want for airtel live or mobileoffice, i've provided you both.
Airtel live:
Connection Name> Airtel Live
Data bearer>gprs
Access point name>airtelfun.com
User Name/Password>(leave blank)
Authentication>Normal
Homepage>live.airtelworld.com
IP Address>100.1.200.99
Connection Security>Off
Session mode>Permanent
Mobile Office:
Connection Name>Mobile Office
Access Point Name>airtelgprs.com
Homepage>www.google.com
IP Address>0.0.0.0
Manual Airtel Gprs Settings
Manual Airtel live settings
Hope it helps.
SOURCE: GPRS gives message data communication error, try again or contact your wap provider
Gmail has the 128-SSL Connection so it cannot be viewed on all phones. If you really want to access Gmail on your mobile download ProfiMail from LonelyCatGames and configure setting for Gmail (GOOGLE THE SETTINGS) in ProfiMail. ProfiMail is like a Outlook Express but for a mobile phone.
# Basic Requirements:
1. A Web Enabled Phone that can be connected to the PC using a data cable, bluetooth or infrared
2. A GPRS activated mobile connection
# Procedure:
1.GPRS activation
In BSNL the balance should be more than Rs. 50 for the GPRS to remain activated. To activate GPRS an sms has to be sent: "GPRS E" to 53733 [removing the quotes]
The usual cost is 2 paise/ Kb. But BSNL has an offer which provides 30 days unlimited net for Rs 189 [by easy recharge from an BSNL outlet] and probably Rs 51 for 7 days unlimited net.
2.Connecting the phone to the PC
The phone can be connected to the PC using the USB data cable, bluetooth or infrared with the help of the driver tools provided with the phone. Hence the phone will be ready to be used as a USB modem connected to the PC.
3.Settings for the Modem on the PC
Start > Settings > Control Panel > Phone and Modem Options > Choose your modem > Click Properties > Choose tab Advanced > At Extra initialization commands, enter code:AT+CGDCONT=1,"IP","www.e.pr" > OK
4.Setting up an internet connection
Though an internet connection can be setup for Motorola MotoRokr E6 using the PhoneTools software provided with the phone, in any usual phone a new connection has to be setup using the DialUP Networking function of Windows using the following process:
Start > Control Panel > Network Connections > New Connection Wizard > Next > Connect to the Internet > Next > Set up my connection manually > Next > Connect using a dial up modem > Next > Choose your modem > Next > Type "bsnl-gprs" > Next > Type "*99#" or "*99***1#" or "*99***2#" or "*99***3#" > Next > The Username box can be left blank > The Password box can be left blank > The Confirm box should left blank too > Next > Finish
While using the setup process through the mobile PhoneTools the following data may be used:
Username : <blank>
Password : <blank>
Access Point Name[APN] : www.e.pr
5.Browser Configuration
In the browser used on the PC, certain proxy configuration must be made in the "Tools>Options>Advanced>Network>Connection Settings" button for Firefox and in the "Tools>Internet Options>Connection Settings>DialUp and Virtual Private Network Settings>Settings" button for Internet Explorer :
Proxy server : 192.168.81.163
Port : 8080
But sometimes this process works without this proxy configuration thus providing better speeds.
Now u r ready to go, connect the net and surf your way through. The net though gets connected at 115.2 Kbps but you will get nothing close to it. Though this net is good for surfing and casual downloads but sites loaded with heavy images and graphics are hard to open eg. Orkut etc. Hope you find this article useful.
Taken from the MGE UPS SYSTEMS, Network Management Card Installation manual (34003641EN/AD)
Run Hyper Terminal on a PC running Windows (9x, Me, NT4.0, 2000 or
higher).
◗ Connect the card to the PC using the cable supplied.
◗ Set up the terminal with the following communication parameters:
◗ 9600 bauds. ◗ 8 data bits.
◗ 1 stop bit. ◗ no parity.
◗ no flow control.
◗ ASCII: "echo typed characters locally" option disabled.
◗ Press the Carriage return key. The configuration menu is displayed.
◗ Enter the password (MGEUPS by default).
◗ The main menu is displayed.
◗ Select one of the items in the configuration menu.
Via the serial link or Telnet
◗ Select the "Agent configuration" command by entering 1.
◗ Select the item numbers and modify all the IP parameters (address, mask, gateway).
◗ Once all the modifications have been made, exit following the instructions on the screen.
Restarting the card Via the serial link or Telnet
◗ Select the "Restart agent" command by entering 6.
◗ Then follow the instructions on the screen.
Restoring the default parameters Via Telnet or Hyper Terminal
◗ Select the "Reset configuration to default" command by entering 5.
how to activate gprs in my handset, drivers, softwares etc. pls send me the details.
