I may be confused with your problem you posted mar13974.
I thought Jumper J9H3 was for the Front Chassis Fan.
By your post, it leads me to believe you want the pin assignments for the Front Panel header on the mobo.
At any rate let's go to Intel Product Support, and the download page for the motherboard manual, for the Intel D865GVHZ desktop mobo,
(MOtherBOard),
http://www.intel.com/support/motherboards/desktop/d865gvhz/sb/CS-010872.htmClick on the blue file name - D865GVHZ_ProductGuide01_English.pdf
After you click you may not see anything happening for up to 30 seconds. The file is downloading in the background.
(Took 16 seconds for me just now with a medium speed DSL connection)
Page 33 shows the location of the Front Panel header on the motherboard.
(C)
Page 34 details the pin assignments
Page 36 shows the Front Chassis Fan header location (Chassis front fan)
3-pin header, doesn't state the pin assignments.
With a 3-wire fan cable,
A) 1 wire is the Power wire. Generally Red
B) 1 wire is the Ground wire. Generally Black
C) 1 wire is the speed sensor wire. Reads how fast the fan is spinning in Revolutions Per Minute
(RPM) Generally Blue, but it's up to the individual manufacturer.
If the above isn't what you had in mind, please state in a Comment.
Regards,
joecoolvette
How many wires lead from the front-panel to connectors?
Are there any labels on any of the connectors,
such as 'PWR SW', 'RESET', 'SPKR' ?
For example, the 'SPEAKER' usually has a connector with 3 holes, with a RED wire into the 1st hole, and a BLACK wire into the 3rd hole, and NOTHING in the middle hole.
You need to give the type of computer case you are using and the make and model number of the motherboard you are using. I this is a intel Motherboard.Go to the website www.intel.com and do a product search for the model of the motherboard and see if they show the set-up. They usually have diagrams of the set-up of the boards in large poster picture form. Ihope this helps you with your problem.
Let me know what are you trying to connect. Are you trying to connect a front panel USB? or some switch??
