SOURCE: Black & White picture
This worked for me push your n/p botten to NTSC then go into setup and put your generl SPDIF output to SPDIF/RAW and then go over to video and make sure your compontent is off hope this helps
SOURCE: DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
