I recently moved my washer away from the wall to install new water hoses. Since I moved it back, it vibrates and makes an awful noise when going through the spin cycle. It does not cut off from being out of balance. The cycle completes. The vibration can literally be felt all over the house. The washer seems to be sitting pretty level. Is there a balancing mechanism that needs to be checked? If so, where and how do I go about it?
Try this for re-setting the balancing mechanism:
With the washer empty, tip tip it forward so that it is just sitting on the front feet. Hold it there for a few seconds, then gently lower the back down. (Often there is a mechanism in the back feet that automatically levels it for you--if this doesn't work, check that the back feet are not damaged.)
Okay sorry, I just investigated further...if the instructions above don't work, then yours needs to be levelled manually. Place a level on top of the machine and and adjust the legs as shown in this PDF manual (which is not in English)
-- see Page 11, Step 12:
http://shared.whirlpoolcorp.com/assets/p...
Rs.2000 credit and 30 day support Advertise Now!
www.Google.com/AdWords
Thanks for your help.! I tipped the washer over and I did adjust the front leg leveler a little bit. I ran a load of wash and it was fine, just like before the problem started.
