You could try Changing the Remote Control code for your DVD recorder. If you have more than one Panasonic device, there's an option to give each device its own Remote Control code. The Default is DVD1. So for FixMick, it sounds like someone may have changed the Remote Control code on your machine to DVD3. For Dador, someone may have changed the Code to DVD1. So you'll need to change the Code on either the device or the Remote to make them match up (see page 19 of the DMR-EH65 Users Manual ... you can download it from the Panasonic website)
Sorry FixMick. I don't know why your display isn't working.
Actually, you'll need to change the Code in the Remote Control to match the Code in the DVD recorder because at the moment the Remote has no effect on the DVD recorder. Page 19 of the DMREH65 User's Manual says:
7 While pressing [ENTER], press and
hold the numbered button ([1], [2] or
[3]) for more than 2 seconds.
8 Press [ENTER].
So for FixMick: You should Press ENTER and 3 for more than 2 seconds. Then you'll be able to use the Remote. If you like, you can change the DVD Recorder's Code back to DVD 1 using the Function button options on the Remote and then change the Code in the Remote back to DVD1 by Pressing ENTER and 1.
For Dador, you only need to change the Code in your Remote to DVD 1... Sounds like you must have gotten a Second Hand Replacement remote that was set up with a Code other than DVD1.
I called the local Panasonic service center here. The reception forwarded my call to the technical team. After I told them of my problem, the only solution is below:
1. Ensure that my player DMR-EH65 is switched on.
2. Press and HOLD button 1 and ENTER simulatneously for 2 seconds.
3. That's it. My DVD recorder works normally.
I have the same problem. When pressing any button in the RC, the player showed DVD1. Any solution?
Hello and thank you for all your suggestions and hints, it was very helpful and useful in solving my problem, hope to be able to return the favour sometime in the future!
fixmick
