The washer doesn't spin the clothes well and the dryer takes forever to dry and I have had this set less than 4 years.The washer doesn't spin the clothes well and the dryer takes forever to dry and I have had this set less than 4 years.
You can't post conmments that contain an email address.
If your towels are coming out the dryest it is probably a problem with it being off balance. Did you make sure that the clothes are even placed in the washer. If you have a bunch of heavy stuff on one side and light stuff on the other side it could cause the same problem.
excellent love a guy willing to try
ok wet cloths
with this model i would the first thing to check is the height of your drain,,,, if the drain ios highter than 6 feet the unit just cant do it
next check your belt, this sometimes becomes stretched, more than 1/2 deflection id change it
Lint is in majority flushed out in drain cycle. make aire the tissue and match books aren't in any pockets. the lint is then deied and separated in the drier , Well so I was told . good luck
Same problem here. But according to Maytag Service, the draining pipe may be too deep inside the draining tube on the wall, thus creating a siphon effect and not allowing the tub to fill.
Their suggestion is to ckeck the pipe and make sure no more than 6-8 inches are inside the draining pipe. This should take care of the suction. We'll see, Imma do that when I get home.
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
