I had a repair person come out and says that the R-22 condenser needs to be changed out due to a leak. Does it need to be changed out or repaired. cost is close to $2,500 to change it out and change over to new freon product.
SOURCE: Replace old Carrier condenser
Don't even think about it. This is an industry where you get what you pay for most of the time. Is your system not working currently? If there is a guy willing to install a system you bought off the internet he doesn't belong in this industry. I have gone behind people like that and had to explain to a homeowner how someone did a complete botch on their job and I have to rip it all out and start over. BE VERY CAREFUL if you want to try that. A company's price is usually a reflection of their quality and level of service. When was the last time you ever got anything of the highest quality for the cheapest price?
SOURCE: Coil leaking freon on the inside unit. Estimate is $2,100!
If indeed your evaporator (indoor) coil is leaking, the best option IS replace it (it may not even BE repairable). If you live in the USA and your furnace is getting old, a new ultra high efficient SYSTEM that qualifies for the tax credit would probably be a better option (Obama will pay 30%).
SOURCE: Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
SOURCE: I have a bryant 24-567c condenser. need replacement
you have a 3.5 ton unit.The evap will work with a new unit but it will not have the 13 seer performance that the new condencer with matching coil will give you.It is getting and harder to find the old 10 seer units check ebay and craigslist.
SOURCE: tube running from AC unit to the house is
we had a big old iceball on the connecting point between hose & external a/c unit this past weekend. we were getting no air - hot cold or otherwise. i changed filters and turned thermostat off, let it sit, noticed major amounts of water dripping out of interior unit. Let it sit several hours (w/lots of towels) turned fan on about 5-6 hours later which was blowing air finally, then after 30 minutes of fan running, turned on a/c - worked like a charm. Until 24 hours later when the thermostat went BLANK! now we have nothing going on, and 98 degrees forecast for tomorrow!
