After a power outage; cannot set the clock. When the (set)"clock" button is pressed it turns the oven light on and off just like the "light" button. SThanks in advance.
I have the same problem. I have tried to turn the power on and off to get it to allow me to set the clock, but doesn't work. It turns the light in the oven on and off. Please help.I have the same problem. I have tried to turn the power on and off to get it to allow me to set the clock, but doesn't work. It turns the light in the oven on and off. Please help.
AnonymousMar 19, 2014
Clock is on but is going fast. It turns one minute after just 40 seconds so the time is always wrongClock is on but is going fast. It turns one minute after just 40 seconds so the time is always wrong
You can't post conmments that contain an email address.
to be honest you should always turn it off at the wall when not in use for safety reasons most common one is to press the two far left buttons and the second to last button all at the same time
I had a Wolf 30F wall oven with a similar problem after power outage. It wouldnt stop beeping with error message related to temperature control. My solution was to turn power of at circuit panel, then reset by pressing and holding the clear button for 5 seconds.
Also note: in my case I had to close the display before switching the panel off. When I tried to the reset process with the panel showing, it wouldn\'t reset.
To reset other various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set the 12-hour clock to the current time of day. It may need to be reset after a prolonged power failure. The clock is visible on the control panel during all modes. If the upper oven timer is set, the clock will not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to set current time of day.
3) Touch CLOCK or ENTER to start clock.
24-HOUR CLOCK
The time-of-day clock can be changed from a 12-hour clock to a 24-hour clock. After the clock has been set, touch TEMPERATURE for three seconds, touch CLOCK, and then touch ENTER. Follow the same sequence to change back to the standard 12-hour clock setting.
Fahrenheit to Celsius
The oven can be changed from Fahrenheit (°F) temperature to Celsius (°C).
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP'). 2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
