I have a Gerber toilet with EcoFlush Model B8104. 1.1 gallon flush system. It functions properly but the water height in the bowl itself seems too high. Sometimes there is splash up when flush occurs. If the water were a little lower I think that would prevent this. It doesn't happen all the time but sufficiently to be bothersome (and gross). Any assistance would be appreciated
The toilet you just installed is a 1.6 gallon flush water saver and will not have the same amount of water in it that your old 3.5 gallon toilet had. The water level may not be able to be raised as this is the nature of the beast.
If you can raise the level it will only be a little and will be done in the tank area by increasing the water level in the tank. If the water level in the tank is at the mark provided it a done deal.
The amount of water refilled into the bowl is done by the tube that runs from the fill valve into the overflow tube of the flush valve so if you put more water into the tank more water will be put into the bowl but the bowl will only hold as much water as the trap weir will let it hold (what the factory has sit it at and is not changeable
Please note this is a pressure assisted flush model and there is basically a plastic tank in the main toilet resevoir. (not your typical/historical model)
Winston - I am having the same problem. Did you ever get an answer?
